New firmware release 1.6.13.b1
A new firmware version has been released. This release is mostly about fixing a problem with the SiPy operating in RCZ2 and RCZ4 were only the first 2 packets of a round of 18 will be transmitted properly. This has been documented in: https://docs.pycom.io/pycom_esp32/library/network.Sigfox.html
Here's the change log:
- esp32/sigfox: Store the last tx timestamp in the RTC memory.
- esp32/sigfox: Add sigfox.rssi() method.
- esp32/sigfox: On RCZ2 and RCZ4 always go back to the default channel after the second Tx.
- esp32: Correct incorrect ordering of ADC1 channel pins.
- esp32: Add more reset causes and make the RTC persistent during deep sleep.
@markj use ubinascii.hexlify(string) to covert it to hex-ASCII.
Not sure if this is the right place to ask, but..
When I try to get the mac address of my Wipy it gives me this:
b'$\n\xc4\x00\xad\xc4'Why does it look look this and how could I get output like a normal mac string?Apparently it is raw bytes in Python 3.
The code, running on the firmware version mentioned here.import network wlan = network.WLAN() print(wlan.mac())
@daniel Hello Daniel, may I kindly ask you to update the firmware repository? There is a substantial lag now.
Re: New firmware release 1.6.13.b1
Just for the record since I see a lot of complaining online about using the Windows upgrade tool: on my LoPy it worked without a problem. Upgrading was 2 minutes work, all scripts were still there.
In the meantime i have moved i2c display from breadboard (really short connections side by side) and solder it on my custom board. All other devices was soldered previously.
But i have also found accidental indentationgc.collectwhich run really rare.Now whole code work since 26 hours - i must test more to see what caused problems.
And i must restart board to see if it still be working that way.P.S. 100 nF nice gift from china for i2c ;-)
@daniel
In this thread:
https://forum.pycom.io/topic/1083/does-deepsleep-work-at-all/
you mentioned that you plan to introduce following modification:
Do not start-up WiFi by default on boot. This will speed up boot times dramatically and reduce power consumption.Can we expect this modification to be implemented anytime soon?
@livius Then it may be the opposite. Do you use the bare chips or modules with the chips embedded. In the latter case they may have already pull-up resistors on-board. In that case, the pull-up value may get too low.
As an anecdote: I ordered recently a pair of ADS1115 modules from china, which did not work. Looking closely at the module I saw, that instead of the pull-up resistors the vendor had assembled capacitors on the board (100 nF), which definitely did not help. I complained at the vendor, and they apologized a lot, and promised to send new modules, but better packed this time!
Yes, i have. But when i wrotemany times
it was ony generality - it happen for me e.g. 3 times per day.
I have on i2c:- BH1750
- BMP180
- HMC5883L
- 2x16 blue LCD
@livius Did you add external pull-up resistors? The internal weak pull-up may be not strong enough to drive several units. Typically 4k7 Ohm is recommended.
@danielm
Bluetooth Classic depends on the chip supplier, Espressif, which hasn't supported it officially yet - first they need to support it in ESP-IDF and only then can Pycom think of adding it in.As far as I know there is no strict schedule on new features from Espressif but they very recently supported Bluetooth A2DP audio sink so SPP may come for ESP-IDF version 3 - but that's many months away, v2 was released less than a month ago.
Also I think that will eat up a lot of RAM, so maybe unwise to even enable it on current hardware until the modules with greatly expanded external RAM are available.
@daniel
Could you please mention planned features for next releases?
When can we expect support of Bluetooth Classic profiles (e.g. SPP)?
@daniel
When I2C as hardware implementation?
I many times got random errors - especially when more devices are connected:OSError: I2C bus errorand this is not capacity problem..
