    New firmware release 1.6.13.b1
    firmware
    13 Posts 7 Posters 4.5k Views 7 Watching
      jmarcelino @danielm
      @danielm
      Bluetooth Classic depends on the chip supplier, Espressif, which hasn't supported it officially yet - first they need to support it in ESP-IDF and only then can Pycom think of adding it in.
      As far as I know there is no strict schedule on new features from Espressif but they very recently supported Bluetooth A2DP audio sink so SPP may come for ESP-IDF version 3 - but that's many months away, v2 was released less than a month ago.
      Also I think that will eat up a lot of RAM, so maybe unwise to even enable it on current hardware until the modules with greatly expanded external RAM are available.
        robert-hh @livius
        @livius Did you add external pull-up resistors? The internal weak pull-up may be not strong enough to drive several units. Typically 4k7 Ohm is recommended.
          livius @robert-hh
          Yes, i have. But when i wrote
          many times
          it was ony generality - it happen for me e.g. 3 times per day.
          I have on i2c:
          • BH1750
          • BMP180
          • HMC5883L
          • 2x16 blue LCD
            robert-hh @livius
            @livius Then it may be the opposite. Do you use the bare chips or modules with the chips embedded. In the latter case they may have already pull-up resistors on-board. In that case, the pull-up value may get too low.
            As an anecdote: I ordered recently a pair of ADS1115 modules from china, which did not work. Looking closely at the module I saw, that instead of the pull-up resistors the vendor had assembled capacitors on the board (100 nF), which definitely did not help. I complained at the vendor, and they apologized a lot, and promised to send new modules, but better packed this time!
              danielm
              @daniel
              In this thread:
              https://forum.pycom.io/topic/1083/does-deepsleep-work-at-all/
              you mentioned that you plan to introduce following modification:
              Do not start-up WiFi by default on boot. This will speed up boot times dramatically and reduce power consumption.
              Can we expect this modification to be implemented anytime soon?
                livius @robert-hh
                In the meantime i have moved i2c display from breadboard (really short connections side by side) and solder it on my custom board. All other devices was soldered previously.
                But i have also found accidental indentation gc.collect which run really rare.
                Now whole code work since 26 hours - i must test more to see what caused problems.
                And i must restart board to see if it still be working that way.
                P.S. 100 nF nice gift from china for i2c ;-)
                • PiAirP Offline
                  PiAir
                  Re: New firmware release 1.6.13.b1
                  Just for the record since I see a lot of complaining online about using the Windows upgrade tool: on my LoPy it worked without a problem. Upgrading was 2 minutes work, all scripts were still there.
                    robert-hh @daniel
                    @daniel Hello Daniel, may I kindly ask you to update the firmware repository? There is a substantial lag now.
                      markj
                      Not sure if this is the right place to ask, but..
                      When I try to get the mac address of my Wipy it gives me this:
                      b'$\n\xc4\x00\xad\xc4' Why does it look look this and how could I get output like a normal mac string?
                      Apparently it is raw bytes in Python 3.
                      The code, running on the firmware version mentioned here.
                      import network
                      wlan = network.WLAN()
                      print(wlan.mac())
                        robert-hh @markj
                        @markj use ubinascii.hexlify(string) to covert it to hex-ASCII.
