    no python prompt after downgrading firmware
    firmware updatebugpython
    21 Posts 2 Posters 8.1k Views 2 Watching
      jmarcelino @rolfhut
      @rolfhut
      Have you followed all the steps in?
      https://github.com/pycom/pycom-micropython-sigfox#the-esp32-version
      before doing the final step (make ... flash) also do this:
      https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/README.md
      CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM is defined in pycom-micropython-sigfox/esp32/sdkconfig.h so it sounds like your build environment isn't setup properly.
      If you still can't get it work can you post exactly what commands you're trying?
        rolfhut @jmarcelino
        @jmarcelino those are the ones I am now trying. I can go back to a single beacon type as soon as I get at least a single signal in. The beacons I use are programmable to be whatever standard we want to use.
        I may pull out a Pi for this project, but the specs for the wipy were too good to not use if I could...
          jmarcelino @rolfhut
          @rolfhut said in no python prompt after downgrading firmware:
          Ok I think I know the problem, you're using the old pycom/pycom-micropython repository instead of new https://github.com/pycom/pycom-micropython-sigfox
          Please use pycom-micropython-sigfox (same for all boards WiPy, SiPy or LoPy)
            rolfhut @jmarcelino
            @jmarcelino
            done that just now, but still:
            LINK build/WIPY/release/application.elf
            text data bss dec hex filename
            935673 167396 70320 1173389 11e78d build/WIPY/release/application.elf
            Building partitions from lib/partitions.csv...
            File "/Users/rwhut/Documents/sideProjects/BluetoothSoilMoisture/code/pycomTest/firmware/micropython/pycom-esp-idf/components/partition_table/gen_esp32part.py", line 356, in <module>
            main()
            File "/Users/rwhut/Documents/sideProjects/BluetoothSoilMoisture/code/pycomTest/firmware/micropython/pycom-esp-idf/components/partition_table/gen_esp32part.py", line 345, in main
            table.verify()
            File "/Users/rwhut/Documents/sideProjects/BluetoothSoilMoisture/code/pycomTest/firmware/micropython/pycom-esp-idf/components/partition_table/gen_esp32part.py", line 83, in verify
            for p in sorted(self):
            TypeError: unorderable types: PartitionDefinition() < PartitionDefinition()
            make: *** [build/WIPY/release/lib/partitions.bin] Error 1
            I'm about to give up and get a RPi.
              jmarcelino @rolfhut
              gen_esp32part.py
              I think this build script expects system Python to be 2.7 (macOS default, that's what I'm using here and it works) and you're probably setup as Python 3
                rolfhut @jmarcelino
                @jmarcelino
                switched to Python 2.7, now get this.
                IMAGE build/WIPY/release/wipy.bin
                esptool.py v2.0-beta2
                Signing OTA image
                make: *** No rule to make target build/WIPY/release/bootloader/bootloader.bin', needed by flash'. Stop.
                I give up.
                  jmarcelino @rolfhut
                  @rolfhut
                  Well you built the application (MicroPython) already so giving up just at the last step? :)
                  Again I'd appreciate if you posted your commands, not just the results.
                  Have you done all the steps in the instructions i.e.
                  $ cd ../esp32
                  $ make BOARD=WIPY -j5 TARGET=boot
                  $ make BOARD=WIPY -j5 TARGET=app
                  Then connect P2 to GND and press reset button before :
                  $ make BOARD=WIPY -j5 flash
                    rolfhut @jmarcelino
                    @jmarcelino I have followed all the steps here:
                    which states to do
                    make BOARD=WIPY flash
                    and never mentions the two other build command you specify.
                    when I run all three commands you gave, it compiles, but now gives final error when trying to connect to the board (which, yes, is booted with G23 pulled to GND).
                    Is there a way to force use of a particular serial? I can see that my board is connected by
                    ls /dev/tty.usb*
                    anyway: the full error is:
                    Use make V=1 or set BUILD_VERBOSE in your environment to increase build verbosity.
                    Flashing project
                      File "/Users/rwhut/anaconda/lib/python3.5/site-packages/serial/serialposix.py", line 265, in open
                        self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
                    FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyUSB0'
                    During handling of the above exception, another exception occurred:
                      File "/Users/rwhut/Documents/sideProjects/BluetoothSoilMoisture/code/pycomTest/firmware/micropython/pycom-esp-idf/components/esptool_py/esptool/esptool.py", line 2294, in <module>
                        main()
                      File "/Users/rwhut/Documents/sideProjects/BluetoothSoilMoisture/code/pycomTest/firmware/micropython/pycom-esp-idf/components/esptool_py/esptool/esptool.py", line 2057, in main
                        esp = chip_class(args.port, initial_baud)
                      File "/Users/rwhut/Documents/sideProjects/BluetoothSoilMoisture/code/pycomTest/firmware/micropython/pycom-esp-idf/components/esptool_py/esptool/esptool.py", line 166, in __init__
                        self._port = serial.serial_for_url(port)
                      File "/Users/rwhut/anaconda/lib/python3.5/site-packages/serial/__init__.py", line 88, in serial_for_url
                        instance.open()
                      File "/Users/rwhut/anaconda/lib/python3.5/site-packages/serial/serialposix.py", line 268, in open
                        raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
                    serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: '/dev/ttyUSB0'
                    make: *** [flash] Error 1
                      jmarcelino @rolfhut
                      @rolfhut
                      Great, glad you got it working. Yes, once the environment is setup you need to take a little detour to the up-to-date build instructions in the esp32 folder README - I linked that in my earlier reply here.
                      Now as you say it's a simple matter of setting the correct environment variable for your serial port before issuing the flash step:
                      export ESPPORT=/dev/tty.usb....
                        rolfhut @jmarcelino
                        @jmarcelino
                        that fixed it.
                        I can now upload my own firmware. Your fix of increasing the stack and putting listining mode in PASSIVE doesn't help though :-(.
                        I'll see if I can go deeper into the scanning part.
                        thanks for all the help
                        Rolf
                        • 2 / 2
