    'Timer' has no attribute 'PERIODIC'
    wipy2.0timerirqinterruptperiodic
    5 Posts 2 Posters 2.0k Views 2 Watching
      Arkaik
      Hi everyone,
      I'm just getting started with timers and irq and I was trying the example code.
      However I have an issue with the initialisation of the timer.
      Here is my code:
      tim1 = Timer(1, mode=Timer.PERIODIC)
      tim1_ch = tim1.channel(Timer.A, freq=100)
      tim1_ch.irq(priority=7, trigger=Timer.TIMEOUT, handler=acquireData_cb)
      And the return
      PYB: soft reboot
        File "main.py", line 42, in <module>
      AttributeError: type object 'Timer' has no attribute 'PERIODIC'
      MicroPython v1.8.6-607-g9c8a0e9e on 2017-05-01; WiPy with ESP32
      I was basically running with a custom firmware so I reflashed the last one but still gets the error
      >>> import os
      >>> os.uname()
      (sysname='WiPy', nodename='WiPy', release='1.6.13.b1', version='v1.8.6-607-g9c8a0e9e on 2017-05-01', machine='WiPy with ESP32')
      I already had a similar issue on pyBoard with the time module where ticks_ms was not available.
      Did someone already had the same problem?
        bucknall
        Hi @Arkaik,
        Where are you getting your example code from? Please see https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/timers.html for our example code within our documentation.
        It's important to note that our timers do not work the same as on the Pyboard.
        Alex
        Developer Evangelist - Pycom
        A 3 Replies Last reply Reply Quote 1
          Arkaik @bucknall
          Hi @bucknall,
          I was using this documentation : https://docs.pycom.io/wipy/library/machine.Timer.html
          I had not realized yet that wipy documentation and wipy 2.0 was not the same...
          Thank you very much, everything is working fine now.
            Arkaik @bucknall
            @bucknall
            As there is not so much documentation about multithreading and interrupts, how could two threads communicate?
            I'm looking for a queue-like mecanism but I can't find anything about it neither in Threading or Timers.
              Arkaik @bucknall
              Hi @bucknall, I finally found this library for using queues on micropython.
              However, this library need collections.deque and uasynio.core.
              1 from collections.deque import deque
              2 from uasyncio.core import sleep
              I went to the github repository, I downloaded collection.deque but I couldn't find uasynio.core anywhere.
              I think I'm not importing libraries correctly because I need to modify the line from collections.deque import deque to from collections import deque
              So now I would like to find the uasyncio.core module to be able to use the queue library ^^
              I hope I do not need to open a new thread for this question.
              If so, I'm sorry ;)
