    Pure Python library for reading DHT sensor on Pycom boards
    dht dht11 dth22
    57 Posts 8 Posters 29.5k Views 9 Watching
    • Jurassic PorkJ Offline
      Jurassic Pork @palmy-nz
      @palmy-nz
      ok it seems good for your module and you have a pull up resistor on your module.
      be careful if you have powered your module with 5v may be you have the signal pin on your pycom module out of order. Try to check it without the dht11 module (input level 0 (gnd) input level 1 (pull up resistor to 3.3v)).
      palmy-nzP 1 Reply Last reply Reply Quote 0
      • palmy-nzP Offline
        palmy-nz @Jurassic Pork
        @Jurassic-Pork
        I got it working now. the problem was i was running an older firmware, after updating to latest, it seems to be working now.
        Thanks to @livius for troubleshooting it with me.
        and @Jurassic-Pork for the library.
        This is a great forum.
          robmarkcole @RobTuDelft
          @RobTuDelft in Pure Python library for reading DHT sensor on Pycom boards:
          Hi Rob, using your library (https://github.com/rbraggaar/DHT_PyCom), DHT22 on Wipy with 10 kOhm pullup, I am getting a temp of 25 deg (correct) but humidity of 99.9% (incorrect). Any ideas what could be wrong?
          Cheers
          RobTuDelftR 1 Reply Last reply Reply Quote 0
          • RobTuDelftR Offline
            RobTuDelft @robmarkcole
            @robmarkcole that one I forked from JP. I was using a 4k7 resistor and it worked well.
            Do you have print('Humidity: {:3.2f}'.format(result.humidity / 1.0))? And
            You did declare the sensor object as th = DTH(Pin('P3', mode=Pin.OPEN_DRAIN), 1)? The last one declares it as a DHT22.
            Does the humidity fluctuate at all?
            Hackster | About me
              @RobTuDelft Yes used those. Humidity and temp constant. Swapped in a DHT11 now and seeing same behaviour. Any tips on how to debug?
              Cheers
                @robmarkcole Can you try it with a 4k7 resistor, maybe 10k is too much? You could also post a picture of your setup and the code fragments you are using.
                Hackster | About me
                  @RobTuDelft I would, but I only have 1 and 10 k Ohm available at the moment.
                  0_1496691300215_upload-20d267d5-acb8-46c0-9a1b-92b7165af7a6
                    robmarkcole @robmarkcole
                    Annoyingly I am unable to upload the code, as it is 'marked as spam' when I try. Nevertheless I am just using the examples in your Github repo
                    Jurassic PorkJ 1 Reply Last reply Reply Quote 0
                      Jurassic Pork @robmarkcole
                      hello,
                      @robmarkcole
                      to see what is wrong, you can uncomment some lines in the file dht.py. The lines 49, 53, 54, 63 with the print function.
                      you must see something like that for the dht11 :
                      the last line in the photo (line 63 print(the_bytes)) has the values for the humidity (32) and for the temperature (22).
                      May be something is wrong with the WiPy module :
                      i use a SiPy module and the other people who have used the library seems to use a LoPy module. If someone can try to use the library with a WiPy module to see if it is OK.
                      Friendly, J.P
                        robmarkcole @Jurassic Pork
                        Hi @Jurassic-Pork thanks for the tips. Here is what I get. The temp and humidity values change each time I reset the board, but look incorrect. E.g. humidity went from 18 to 37 on a restart.
                        Cheers
                        entry 0x4009fd9c
                        ('192.168.0.23', '255.255.255.0', '192.168.0.1', '192.168.0.1')
                        [1, 0, 1, 1, 0, 0, 1, 1, 0, 0, 0, 1, 1, 1, 0, 0, 0, 1, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1, 1,
                         1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0,
                         0, 1, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0,
                         1, 0, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1,
                         1, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1,
                         1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
                         1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1]
                        [2, 2, 3, 2, 1, 4, 1, 4, 1, 1, 1, 1, 2, 1, 1, 1, 1, 2, 1, 4, 1, 1, 4, 1, 1, 1, 1, 1, 1, 1, 1, 2, 1, 1, 4, 4, 1, 4, 4, 4]
                        40
                        [37, 0, 18, 0, 55]
                        8
                        Temperature: 18 C
                        Humidity: 37 %
                          hello,
                          @robmarkcole
                          look at this this timing for the AM2302 data acquisition :
                          the acquisition begins when the start signal after 19 ms is put to level 1 :
                          def read(self):
                                  #time.sleep(1)
                                  # send initial high
                                  #self.__send_and_sleep(1, 0.025)
                                  # pull down to low
                                  self.__send_and_sleep(0, 0.019)
                                  # collect data into an array
                                  data = self.__collect_input()
                              def __collect_input(self):
                                  # collect the data while unchanged found
                                  unchanged_count = 0
                                  # this is used to determine where is the end of the data
                                  max_unchanged_count = 100
                                  last = -1
                                  data = []
                                  m = bytearray(800)        # needs long sample size to grab all the bits from the DHT
                                  irqf = disable_irq()
                                  self.__pin(1)
                          then we store the level values :
                                 for i in range(len(m)):
                                      m[i] = self.__pin()      ## sample input and store value
                          your samples data begin with a 1 and me with a zero (begining of the response signal)
                          try to see if you have always a 1 for the first data.
                            @Jurassic-Pork Appears to always start with 1..
                              hello,
                              @robmarkcole
                              May be you have the Delay DHT in your first data and not me.
                              In the parse data function :
                                  def __parse_data_pull_up_lengths(self, data):
                                      STATE_INIT_PULL_DOWN = 1
                                      STATE_INIT_PULL_UP = 2
                                      STATE_DATA_FIRST_PULL_DOWN = 3
                                      STATE_DATA_PULL_UP = 4
                                      STATE_DATA_PULL_DOWN = 5
                                      state = STATE_INIT_PULL_UP
                                      lengths = [] # will contain the lengths of data pull up periods
                                      current_length = 0 # will contain the length of the previous period
                                      for i in range(len(data)):
                                          current = data[i]
                                          current_length += 1
                                          if state == STATE_INIT_PULL_DOWN:
                                              if current == 0:
                                                  # ok, we got the initial pull down
                                                  continue
                                                  continue
                                          if state == STATE_INIT_PULL_UP:
                                              if current == 1:
                                                  # ok, we got the initial pull up
                                                  state = STATE_DATA_FIRST_PULL_DOWN
                                                  continue
                                                  continue
                                          if state == STATE_DATA_FIRST_PULL_DOWN:
                                              if current == 0:
                                                  # we have the initial pull down, the next will be the data pull up
                                                  state = STATE_DATA_PULL_UP
                                                  continue
                                                  continue
                                          if state == STATE_DATA_PULL_UP:
                                              if current == 1:
                                                  # data pulled up, the length of this pull up will determine whether it is 0 or 1
                                                  current_length = 0
                                                  state = STATE_DATA_PULL_DOWN
                                                  continue
                                                  continue
                                          if state == STATE_DATA_PULL_DOWN:
                                              if current == 0:
                                                  # pulled down, we store the length of the previous pull up period
                                                  lengths.append(current_length)
                                                  continue
                                                  continue
                                      return lengths
                              try to put the state variable to STATE_INIT_PULL_DOWN at the begining of the function :
                               state = STATE_INIT_PULL_DOWN
                              Friendly, J.P
                                @Jurassic-Pork said in Pure Python library for reading DHT sensor on Pycom boards:
                                Thanks JP. Making this change I get:
                                entry 0x4009fd9c
                                [1, 0, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 1, 1, 1, 0, 0, 1, 1, 0, 0, 1, 1, 1, 0, 0, 0, 1, 1, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0,
                                 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 1, 1, 1, 0,
                                 0, 1, 1, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 1, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1,
                                 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1, 1, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 1, 1, 1, 0, 0, 1, 1, 1, 1, 0, 0, 1, 1, 1,
                                 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
                                 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1]
                                [1, 1, 3, 2, 3, 3, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 3, 2, 1, 2, 3, 1, 1, 1, 2, 1, 2, 1, 2, 1, 1, 3, 1, 1, 3, 4, 3]
                                39
                                And nothing more
                                  hello,
                                  @robmarkcole
                                  Ok it's not good because you have only 39 values (last line)
                                  it's seems that your module is slower than mine because the max value for length of 1 level is 4 and for me 5 (or it is the dht ) . What is exactly your Pycom Module ? frequency ? firmware ?
                                    Hi @Jurassic-Pork
                                    • it's a Wipy 2.0,
                                    • will check firmware tonight but only updated 2 days ago so presumably the latest,
                                    • how to check the frequency?
                                      @robmarkcole
                                      try this :
                                      machine.freq() # get the CPU frequency
                                      os.uname().release
                                      for me :
                                       import machine
                                       import os
                                      160000000
                                       os.uname().release
                                      '1.6.12.b1'
                                        @Jurassic-Pork s
                                        0_1496904069365_upload-4c762e17-60b1-4129-82b3-268d0666a29a
                                          hello,
                                          @robmarkcole have you still your problem ? the new firmware release v1.7.7.b1 have a new function pulses_get that can improve my DHT library.
                                            @Jurassic-Pork I just updated my firmware today :-) How to use the new function?
                                            • 3 / 3
