Can't upload code in Atom. / Issues with Wi Fi Windows 10
Hi there,
I am having two issues with my WiPy 2.0.
- WiPy does not connect to wireless in Windows 10, I can see "wipy-wlan-XXX" on "Network Settings" but it does not connect at all, following message is displayed. "No Internet, Secured". Does anyone has similar issue in Windows 10?
I can connect by Wi Fi in my Linux debian PC, but Atom is not supported for my old linux box (32bits), so I am stuffed on this one. any advises, besides FTP and putty lol
- I can connect using COM3 to the board, and Atom seems to work OK, but, if I try to sync and run the project, I have following message.
I have created both files main.py and boot.py, and it is basically "Traffic lights" from the tutorial.
I would appreciate any help, or suggestion.
Cheers
Colombian1976
Update completed, issue still happening. I think I will do what you are doing. I also tried to install atom in my Linux PC (Debian wheezy), though it did not work, not so sure if it is because .deb is for Ubuntu, although it is a debian under the hood.
Cheers
Colombian1976
@ColombianAus
I do not know what is your firmware version but i see that it is quite recent (your is on 2017-06-16).
Try to update to newestos.uname() (sysname='WiPy', nodename='WiPy', release='1.7.4.b1', version='v1.8.6-679-g0aa833b4 on 2017-06-23', machine='WiPy with ESP32')but maybe this is atom plugin issue. I do not use it then can not help more
i play with clear ftp (filezilla). Throught it i put modified files.
I can connect to the board now, but when I try to sync the files, it just breaks the wi fi connection. any ideas?
Cheers
Colombian1976
@ColombianAus said in Can't upload code in Atom. / Issues with Wi Fi Windows 10:
