Uart Interrupt Wipy 2.0
I need to use the uart interrupt but I found the example for wipy 1.0 but for wipy 2.0 I can't make it work.
Is there any example to use uart irq for WiPy 2.0?
Regards
@bucknall said in Uart Interrupt Wipy 2.0:
We currently do not support interrupts in the ESP32 MicroPython branch for the UART bus. I know this is on the roadmap of things to do, so I'll check with Daniel to see where we are with this!
Thanks for your patience!Hi Guys,
there are updates that concern UART interrupt?
This aspect is very important!
@jakarman12 Ah ok!
Hi @bucknall:
Of course, here it is.
from machine import UART import pycom import time uart = UART(1, baudrate=9600) pycom.heartbeat(False) UART.irq(UART.RX_ANY, priority=1, handler=irq_uart1, wake=machine.IDLE) def irq_uart1 (): print ("Uart Interrupt") pass uart.write('hello') while 1: pass This is the error: **Traceback (most recent call last): File "main.py", line 7, in <module> AttributeError: type object 'UART' has no attribute 'irq'**
Hi @jakarman12
Could you please give an example (in MicroPython) of what you are trying to do?
