Uart Interrupt Wipy 2.0
I need to use the uart interrupt but I found the example for wipy 1.0 but for wipy 2.0 I can't make it work.
Is there any example to use uart irq for WiPy 2.0?
Regards
Hi @jakarman12
Could you please give an example (in MicroPython) of what you are trying to do?
Hi @bucknall:
Of course, here it is.
from machine import UART import pycom import time uart = UART(1, baudrate=9600) pycom.heartbeat(False) UART.irq(UART.RX_ANY, priority=1, handler=irq_uart1, wake=machine.IDLE) def irq_uart1 (): print ("Uart Interrupt") pass uart.write('hello') while 1: pass This is the error: **Traceback (most recent call last): File "main.py", line 7, in <module> AttributeError: type object 'UART' has no attribute 'irq'** -
@jakarman12 Ah ok!
We currently do not support interrupts in the ESP32 MicroPython branch for the UART bus. I know this is on the roadmap of things to do, so I'll check with Daniel to see where we are with this!
Thanks for your patience!
@bucknall said in Uart Interrupt Wipy 2.0:
Thanks for your patience!Hi Guys,
there are updates that concern UART interrupt?
This aspect is very important!
