    BME280 on the LoPy
    bme280lopyi2c
    41 Posts 12 Posters 16.7k Views 12 Watching
      Butch @binux
      @binux I am seeing exactly the same problem with 1.6.10b1. I have Vin on the BME280 tied to 3.3v on the LoPy, I have ground on the BME280 tied to gnd on the LoPy, I have SDA on the BME280 tied to pin P9 on the LoPy, and I have SCL on the BME280 tied to pin P10 on the LoPy.
      >>> from machine import I2C
      >>> import bme280
      >>> i2c = I2C(0, I2C.MASTER, baudrate=100000)
      >>> i2c.scan()
      [118]
      >>> bme = bme280.BME280(i2c=i2c)
        File "bme280.py", line 186, in __init__
        File "bme280.py", line 192, in _load_calibration
        File "bme280.py", line 152, in readU16LE
        File "bme280.py", line 135, in readU16
      OSError: I2C bus error
      As you can see, the I2C bus has something on it at hex address 0x76 (118 decimal). However, initializing the BME280 fails.
      Any help, anyone? Please?
      • RobTuDelftR Offline
        RobTuDelft
        You have to specifiy the address when creating the sensor object:
        def __init__(self, address, i2c):. I don't see the address getting the default address assigned here, maybe that's your issue?
        edit:
        I was looking at the wrong class
        address=BME280_I2CADDR
        It gets the default address from there
        self._device = Device(address, i2c)
        Hackster | About me
        • ledbelly2142L Offline
          ledbelly2142
          I am trying to use the same library with a BME280 and am experienceing the exact same issue with firmware version 1.7.4.b1
          same error:
            File "main.py", line 9, in <module>
            File "bme280.py", line 198, in init
            File "bme280.py", line 204, in _load_calibration
            File "bme280.py", line 164, in readU16LE
            File "bme280.py", line 147, in readU16
          Did anyone get this to work?
            Butch @ledbelly2142
            @ledbelly2142 said in BME280 on the LoPy:
            same error:
            Try my fork of the library: https://github.com/ButchAnton/LoPy_BME280
              ledbelly2142 @Butch
              @Butch
              yup, thats what I'm using. I forked it. Why the init.py file?
                Butch @ledbelly2142
                @ledbelly2142 That makes it into a package: https://docs.python.org/2/tutorial/modules.html#packages
                  ledbelly2142 @Butch
                  @Butch
                  I still have the same issue, just updated to the latest firmware 1.7.5.b2
                  In the main.py I'm just trying to print out values in the console, I have:
                  import bme280 # from bme280
                  i2c.scan()
                  #i2c = machine.I2C(0, pins=('GP11', 'GP10'))
                  pycom.heartbeat(False)
                  temp = BME280.temperature()
                  humid = BME280.humidity()
                  press = BME280.pressure()
                  alti = BME280.altitude()
                  #for cycles in range(10): # stop after 10 cycles
                  while(true):
                      print(temp) # read temperature
                      time.sleep(2)
                      print(humid) # read humidity
                      time.sleep(2)
                      print(press) # read Pressure
                      time.sleep(2)
                      print(alti) # read altitude
                      time.sleep(2)
                    Butch @ledbelly2142
                    @ledbelly2142 Try following the line of logic I tried in the python REPL: import, instantiate, and initialize:
                    >>> import bme280
                    See where that takes you.
                    The original problem I ran into and ultimate fixed was that the 8- and 16-bit writes needed the value to be written to be a bytearray, not the raw value. Beyond that, all I added was a wrapper for altitude.
                      ledbelly2142 @Butch
                      @Butch
                      For me, the issue comes up from :
                      Thats where I get the errors indicating an I2C bus error.
                      I SDA on pin 9 and SCL on pin 10.
                      Could it be a bad sensor?
                      So I unplugged the BME280 sensor and got the same error.
                        Butch @ledbelly2142
                        @ledbelly2142 It's possible that it's a bad sensor. Do you have another one to try? You might also check to make sure that i2c.scan() is returning the same address that is used in the BME280 library. If it isn't, you'll have to change the address in the library.
                          ledbelly2142 @Butch
                          @Butch
                          That looks to be it. The I2C address was 77, not 76... weird. I did not think to check the I2C address.
                            Devang Sharma
                            Hello Everyone,
                            I'm using LoPy and I've got the similar type of error as @binux got.
                            I'm getting the following error:
                            This is my code:
                            Please guide me solving this!
                            Thank You.
                              robert-hh @Devang Sharma
                              @devang-sharma The required positional argument is 'little' in the call of from_bytes(). The API was changed a while ago. You have to modify the script BM280.py into:
                                      result = int.from_bytes(
                                          self._i2c.readfrom_mem(self._address, register, 2), little) & 0xFFFF
                              The same in function readU8().
                                Devang Sharma @robert-hh
                                @robert-hh I've done changes as you said but got the NameError as:
                                "name 'little' is not defined". How can I solve it?
                                Thank You.
                                  @devang-sharma Sorry, it should be a string:
                                              self._i2c.readfrom_mem(self._address, register, 2), 'little') & 0xFFFF
                                    @robert-hh, that worked! Thanks, but the same error for write8:
                                    Is there any link to the changed API or library? That would be better than posting every single error! :'D
                                    EDIT: Solved the error. Replaced value.to_bytes(1) with "value"! No more Errors!
                                      @devang-sharma No specific API doc needed, since it is standard Python behaviour now. It was incompatible before, but I'm not shure, for which MicroPython version. It may be that the Pycom branch always was compatible to the Standard.
                                      And yes, even in that case changes toward language compliance may break code, so it should be noted.
                                        robd
                                        There are quite a few entries on the BME280.
                                        I have been reading them and I am still not able to fix my issues.
                                        I have tried several of the libraries and I am just at a stand still.
                                        When I do a scan of the I2C port I get 0x76 so I know that the sensor is there.
                                        What I get is as follows (firmware rev 1.10.2.b1)
                                        Thank you,
                                          robert-hh @robd
                                          @robd Actually, which bme280 code are you using at the moment? I'm a little bit lost too.
                                            Devang Sharma
                                            @robd I've faced a similar issue and added argument 'little' as @robert-hh suggested which worked for me. I don't know which library you're using. But I've been using this:
                                            https://github.com/LoRaWeather/BME280-LoPy-TTN/tree/master/Program/lib
                                            • 1 / 3
