    Analog CO2 Sensor for LoPy, can 5v pin power it?
    co2lopyadc5vdcsensor
    15 Posts 4 Posters 5.4k Views 4 Watching
      robert-hh @ledbelly2142
      @ledbelly2142 The 5V pin is connected to the USB 5V or Vin. So it should source enough power to run the sensor. In you example, to use the attenuator, the syntach is:
      adc = machine.ADC() # create an ADC object
      apin = adc.channel(pin='P16', attn=machine.ADC.ATTN_11DB) # create an analog pin on P16 & connect CO2 sensor
      value = apin()
      print("ADC count = %d" %(value))
      The value will never be 0, since the output of the sensor is in the range of 0.4..2 V. The esp32 is quite noisy, so you should average over a handful samples, like 10.
      • ledbelly2142L Offline
        ledbelly2142
        @jmarcelino
        Thanks! yes, I only had 'import macine'
        Now I get a reading, but it does not look like the sensor is working correctly. I am using ATTN_11DB to make the math conversion easier value * (3300/1024.0)
        The raw ADC count is still high, at 883 and its not changing much.
        Perhaps I am missing something in the documentation, is the ADC count a division of something? e.g. 883 count = 0.83v?
          @ledbelly2142 The range of the ADC is 0..4096. With an attenuation of 11DB, the reading of 883 tells 883*3.3/4096V = 0.71V
          ledbelly2142L 1 Reply Last reply Reply Quote 1
            ledbelly2142 @robert-hh
            Thanks, I could not find where in the documentation the ADC range?
            The vendor of the CO2 sensor used the formula to get CO2 ppm:
            value*(3300/1024)
            I think there are 1024 is the steps on an arduino for the analog in.
            So I think the step function to interpret the ppm should be:
            value*(3300/4096) which would put us in the range of 711 ppm of CO2. Which sounds about right given that is on my desk right in front of me.
              ledbelly2142
              Here is what I used for this sensor:
              from machine import ADC
              apin = adc.channel(pin='P16', attn=ADC.ATTN_11DB)   # create an analog pin on P16 & connect CO2 sensor
              print("")
              print("CO2 sensor Warming Up")
              #time.sleep(180) # CO2 sensor needs 3 minutes to warm up
              print("Reading CO2 Sensor...")
              value = apin()
              # LoPy  has 1.1 V input range for ADC
              co2 = value * (3300/4096.0)
              print("CO2 Level = %5.1f ppm" % (co2))
                jmarcelino @ledbelly2142
                @ledbelly2142
                The ADC is 12 bit so the range is 0..4095 as @robert-hh explained. The reference is 1.1 Volts.
                At ATTN_11DB the full scale goes to 3.9V: 1.1 * math.pow(10.0, 11.0/20.0) so a more correct formula is value * (3900/4096)
                Finally the sample code you linked doesn't just use the voltage reading (what you have now) as the concentration, it takes a few extra calculations.
                    int voltage_diference=voltage-400;
                    float concentration=voltage_diference*50.0/16.0;
                I haven't read the datasheet but I guess you'll need to do the same in your code.
                  ledbelly2142 @jmarcelino
                  @jmarcelino
                  Thanks for your reply and help, I appreciate it. I understand the ADC bit range to 3900 instead of 3300--makes sense.
                  I am missing the voltage reading completely :( I was going on the ADC example code and explanations. It's gotta be in the documentation somewhere that I can't find. Even when I search the docs for 'voltage', only DAC shows up, not in ADC.
                  Why do we need the voltage difference -400 value?
                  How do I apply the concentration to get the value?
                  is that something like:
                  value = apin()
                  co2 = value * concentration(3900/4096.0)
                  Or would it just be
                    @ledbelly2142
                    I can't find any proper datasheet for your sensor but this plot shows everything you need to know:
                    At 0 ppm the sensor outputs 0.4v so you you need to subtract 400 (in millivolts) from your voltage reading (the voltage_diference in that formula)
                    Then you know that 0.4 volts to 2.0 volts (a 1.6 volt range or 0 to 1600 in your voltage_diference from above) equates to a range of 0 to 5000 ppm.
                      @jmarcelino
                      Thank you, makes sense now. Really appreciate it.
                      Cheers
                      • bmarkusB Offline
                        bmarkus
                        Analog CO2 sensors does not really fit to todays IoT environment specially low power battery operated devices due to high power consumption and slow operation, long settle time. Take a look on Gas Sensing Solutions sensors. They are fast low power devices with digital interface. It is the data sheet of model I'm using with a LoRaWAN sensor (not PyCom), connected via serial line:
                        https://www.gassensing.co.uk/media/1050/cozir_ambient_datasheet_gss.pdf
                          ledbelly2142 @bmarkus
                          @bmarkus
                          The COZIR sensors look nice. Are they in the sub $100 range? I also have CO2 sensors from co2meter.com, the K30. But they are a pain to work with and give very little support. At some point I wanted to create an I2C driver for micropython, but put it off because of the support. Another IoT option for low power gas sensors is Spec-Sensors We have used some of their stuff in the past, but they don't have CO2.
                            ledbelly2142
                            Here's the updated code for this sensor with everyone's help. @jmarcelino @robert-hh
                            In testing it, the results seem reasonable. Not super accurate but enough within 100ppm. Digy-Key has them for $58
                            print("")
                            #need initial delay (180) # CO2 sensor needs 3 minutes to warm up
                            value = apin()
                            co2 = (value-400) * (3900/4096.0)
                            • bmarkusB Offline
                              bmarkus @ledbelly2142
                              @ledbelly2142 said in Analog CO2 Sensor for LoPy, can 5v pin power it?:
                              @bmarkus
                              First hit of Google search gives $109 USD
                              https://www.co2meter.com/products/cozir-0-2-co2-sensor
                              As an indication you can visit the webshop of ChipCAD, a Hungarian distributor
                              https://shop.chipcad.hu/Welcome/Default.aspx?scenarioID=360&pid=1878
                              Prices are in HUF (Hungarian Forint), VAT not included. At the moment 1 USD = 262.6 HUF
                              But it may vary by distributor, quantity, shipping conditions, custom, etc. and model. You can ask GSS to advice where to buy it, they are good.
