    SiPy reboots during boot process - no control
    sipyfirmwarereboot
    9 Posts 4 Posters 2.4k Views 4 Watching
    • V Offline
      Vercellotti
      Your assistance please, team.
      In trying to set up my WLAN, I did something I cannot fathom and have now locked myself out of my Sipy. The unit starts booting and then does a dump (see below). No amount of hard reset gets me back to a workable unit - 3v3 to P12 does not help.
      Right now I can find no intervention that will get me to a point where I have control. It starts the boot and then goes straight to the dump and reboots.
      Please advise how I can do a VERY HARD factory reset back to the starting point.
      ![0_1492554031221_Capture.JPG](Uploading 100%)
      Greg
      L robert-hhR 2 Replies Last reply Reply Quote 0
        livius @Vercellotti
        @Vercellotti
        Reflash with firmware updater tool
        can you post textual view of core dump?
        • B Offline
          bessonf
          I blocked my lopy, when I wanted to write on SD card while I was already using one of the SD pins for a UART link. As soon as the Lopy restarts it restarts again in the second and again and again ...
          To correct this I use the safeboot mode:
          Https://docs.pycom.io/lopy/lopy/general.html
            livius @bessonf
            @bessonf
            as you can see he tried this without success
              robert-hh @Vercellotti
              @Vercellotti If the problem ist the code either in boot.py or main.py and whatever you call in there, then reflashing the firmware alone will not help, because that leavse the file system untouched. You have to erase flash first. That can be done with esptool.py, which is embedded in the pyupdate package, or here: https://github.com/espressif/esptool/tree/907273664ada32fc33f3fbfeba99550512c67e4d
              issue python esptool.py --help
              for the list of command options.
              L 1 Reply Last reply Reply Quote 1
                livius @robert-hh
                @robert-hh said in SiPy reboots during boot process - no control:
                you have right, only format command erase it or reflash partition
                and because of that i always in development stage do simple trick like
                boot.py
                if pin()==1:
                  execfile('myboot.py')
                and same in main.py
                if pin()==1:
                  execfile('mymain.py')
                and i set pin to low when i have problem and then it does not execute my files
                • V Offline
                  Vercellotti
                  Thank you for all your help. It certainly gave me some guidance on the problem, and some new ideas. @Livias, great idea and I will implement such.
                  The solution was to reflash the unit (I found the Pycom Firmware Updater) which worked well. I then manually ran the Wifi setup script and got back control over wifi.
                  The problem still exists if I put the same script in the boot.py file. It would seem that the bootloader is not completed before boot.py is run, and so my wifi set up script is running while still booting (is this possible?). I will introduce a time sleep and see if this makes a difference.
                  Questions : Does the wifi connection need to be set up through the boot.py, or can you flash it more permanently to the unit?
                  Thanks again and I look forward to further feedback.
                    @Vercellotti WiFi set-up is usually done in main.py or a script, called by main.py. boot.py is mostly used to set UART and eventually set another script executed instead of main.py.
                    Besides that, they should behave identical. If they fail in a hard manner, the device will reboot.
                    V 1 Reply Last reply Reply Quote 0
                    • V Offline
                      Vercellotti @robert-hh
                      @robert-hh Thank you. I will work on that advice.
