    Onewire DS18B20P
    tutorial onewir
    1 Posts 1 Posters 1.1k Views 1 Watching
    • F Offline
      federico
      Wiring WiPy ver. 2.0 with DS18B20P
      1 - # DS18B20P data line connected to WiPy pin P10
      * DS18B20P - parasite mode wiring
      A - # * DS18B20P GND pin connected to DS18B20P Vin pin
      2 - # * DS18B20P GND pin connected to WiPy GND
      B - # * in series to DS18B20P/WiPy data line connection point
      3 - # * mount an 1 Kohm resistor that will be connected to WiPy 3V3
      In micropython example code I have divided by 100
      the reading value to obtain the right temperature value
               print(temp.read_temp_async()/100) # added /100
      ** see the attachment : WiPi2_DS18B20P_readings.jpg
      If I am right the tutorial example must be upgraded
      https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/onewire.html?highlight=onewire
      One-wire driver
      This tutorial explains how to connect and read data from a DS18x20 temperature sensor.
      Basic usage
      from machine import Pin
      from onewire import DS18X20
      from onewire import OneWire
      #DS18B20 data line connected to pin P10
      ow = OneWire(Pin('P10'))
      temp = DS18X20(ow)
      print(temp.read_temp_async()/100) # added /100 to have Celsius degrees
      temp.start_convertion()
