    Does network.WLAN.deinit() turn off WiFi radio part of ESP32 in 1.6.13.b1?
    consumptiondeinit
    7 Posts 4 Posters 3.5k Views 4 Watching
      danielm
      I am trying to figure out if network.WLAN.deinit() turns off WiFi radio part of ESP32 in 1.6.13.b1.
      I am using following method for power consumption measurement:
      http://community.silabs.com/t5/32-bit-MCU/How-to-use-an-STK-to-measure-current-consumption-on-your-own/td-p/98363
      boot.py:
      import os
      from machine import UART
      uart = UART(0, 115200)
      os.dupterm(uart)
      main.py:
      from network import WLAN
      wlan = WLAN()
      wlan.deinit()
      After connecting STK board as power source to Expansion Board 2.0 with LoPy through battery JST connector I observed current spike immediately:
      alt text
      Or after some time:
      alt text
      alt text
      In case of not calling wlan.deinit() in main.py current spikes appear immediately and are repeating periodically:
      alt text
      It seems that network.WLAN.deinit() makes some difference in power consumption patter. What could be causing those remaining spikes in case WLAN is initialized?
        danielm
        Last sentence should be:
        What could be causing those remaining spikes in case WLAN is NOT initialized?
        • on4aaO Offline
          on4aa
          I am also interested in turning WLAN completely off. Have you found an answer in the meantime?
          I might be mistaken, but Bluetooth BLE might be employing the same radio and antenna but with less power.
            jmarcelino @on4aa
            @on4aa
            Yes WLAN.deinit() powers off WIFi radio.
            You now also have pycom.wifi_on_boot([enable]) to disable WiFi even before deinit is called: https://docs.pycom.io/chapter/firmwareapi/pycom/pycom.html
            BLE is currently very similar in energy to WIFi this will be addressed in the next major update of the ESP-IDF low level libraries
            on4aaO K 3 Replies Last reply Reply Quote 2
            • on4aaO Offline
              on4aa @jmarcelino
              @jmarcelino That did it. Thanks!
              I was reading the WLAN section of the documentation where this is not mentioned. As a newbee, it never crossed my mind to also look in the pycom section.
              Perhaps a cross link in the WLAN documentation section would easy the path for others to come…
              I definitely looking forward to BLE support. I do hope it will be possible to switch off WLAN whilst keeping BLE.
              • on4aaO Offline
                on4aa @jmarcelino
                @jmarcelino With pycom.wifi_on_boot(False), I started using rshell, which I truly enjoy.
                It allows me to keep on writing code with vim (instead of atom) whilst rendering the upload and running of scripts really easy.
                The rshell command line tool definitely also merits mentioning in the documentation.
                • K Offline
                  kavehoo @jmarcelino
