    How to make HTTPS requests
    lopyhttpssslsockets
    7 Posts 3 Posters 3.3k Views 3 Watching
      lebucur
      Hello, is there a way to make HTTPS requests?
      I have tried many different ways, but even wrapping a SSL socket generated errors. I am really confused right now.. I have LoPy with the latest firmware (1.6.13.b1).
      • I Offline
        Innocenzo @lebucur
        @lebucur SSL should work if the WiPY (LoPy) is the client. The problem with ssl.wrap_socket() arises when the WiPy (LoPy) is the Server Side. Try also to use the urequests.py lib.
          danielm
          I could do POST over HTTPS using urequests.py library, however it is unstable/unreliable:
          https://forum.pycom.io/topic/1061/https-post-using-urequests-py-and-guru-mediation-error/
          It works good enough for doing experiments but not for long-running applications.
            lebucur @danielm
            Thanks,
            Will these be implemented officially in the near future? What alternatives do I have?
            I guess I could do well with TCP + separate encryption, right?
              danielm
              I hope that the issue will be fixed soon, however it is fully in hands of Pycom team or maybe something will have to be fixed by Espressif in esp-idf.
              You could try to write your own library which will compile requests and parse responses, however if the issue is caused e.g. by ssl.wrap_socket() you will face similar behavior.
                lebucur
                I want to share with you the code that worked for me afterall:
                import socket, ssl
                server = ('192.168.0.105', 25566)
                sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM) #def socket.IPPROTO_TCP
                sslsock = ssl.wrap_socket(sock)
                sslsock.connect(server)
                sslsock.send('GET /ping HTTP/1.0\r\n\r\n')
                print(sslsock.recv(200))
                sslsock.close() #automatically closes underlying socket
                import urequests
                url = 'https://192.168.0.105:25566/ping'
                resp = urequests.request('GET', url)
                print(resp.content)
                import urequests
                url = 'https://192.168.0.105:25566/register'
                headers = {'content-type': 'application/json'}
                data = {'email':'email@gmail.com', 'password':'password', 'fullName':'My Name'}
                resp = urequests.request('POST', url, json=data, headers=headers)
                print(resp.content)
                I still get OSERROR or EHOSTUNREACH from time to time, especially when I try to make these requests one after another. My guess is that there are some resources that are not freed when closing the socket.
                  danielm
                  Does it work reliably if repeated for hundreds of requests? Properly raised exceptions are acceptable in my opinion.
