possibility to use Lora objenious network in France with Lopy ?
  • hello,
    i live in France and we have a Lora national network (commercial) objenious with 83 % of coverage of the whole country. It seems that may be , there will be an agreement between pycom and objenious to use the lopy module with this network. Is it true ? if it is true when and what will be the conditions ?
    Friendly, J.P
  • @stef , sensor type Pycon should be avail:
    0_1504110986341_upload-1a444523-8dc6-46da-9fee-46a782b7b215
  • Hi all ,
    trying to connect to objenious network ( thanks raxy code )
    i 've got a invalidMIC error on join .
    Is it linked to the keys ? ( i use their XLS template to import the sensor)
    What sensor type did you use for the LoPy ? ( as pycom not in the sensor list )
    Thank's in advance.
    Stephane A.
  • @gas email contact@objenious.com , then ask for Nicolas Carvallo.
  • @gas Have you tried the code raxy posted?
    I did (with some rearrangements) and it works. I suppose what is important is to specify adr and device_class when defining the LoRa object. Also, when calling the join method, I had not specified dev_eui in the auth parameter which can be (but it should not matter very much).
    Thanks @raxy by the way (-;
    It's quite off topic but now I have to figure out how to properly use machine.deepsleep() along with LoRaWAN. As waking up from deep sleep resets the board, one has to re-join the LoRaWAN network after every deep sleep interval... Unless there is a way to "keep" the LoRaWAN session active despite a board reset?
  • @raxy I'm interested too Thank Nicolas C,
    if you can share
  • ok here is the code...
    #-- lora1.py, test of objenious uplink / downlink
    # by raxy asOf 20jun17 : works OK in class C!
    from network import LoRa
    import binascii
    import struct
    def lora_cb(lora):
        global s
        events = lora.events()
        if events & LoRa.RX_PACKET_EVENT:
            data = s.recv(64) # will return immediately w/ or w/o data
            print("<<",data)
    # create an OTAA authentication parameters
    app_eui = binascii.unhexlify('xxx')
    # Initialize LoRa in LORAWAN mode.
    lora = LoRa(mode=LoRa.LORAWAN, adr=True, device_class=LoRa.CLASS_A)
    #your Class A keys
    dev_eui = binascii.unhexlify('yyy'.replace(' ','')) #classe A
    app_key = binascii.unhexlify('zzz'.replace(' ','')) #classe A
    # xor Initialize LoRa in LORAWAN mode.
    lora = LoRa(mode=LoRa.LORAWAN, device_class=LoRa.CLASS_C, adr=True)
    #your Class C keys
    dev_eui = binascii.unhexlify('xxx') #classe C
    app_key = binascii.unhexlify('yyy') #classe C
    print('dev_eui==',dev_eui)
    # join a network using OTAA (mandatory on objenious WAN)
    lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0)
    # wait until the module has joined the network
    while not lora.has_joined():
        print('joining..')
        time.sleep(3.0)
    print('connected to Objenious LoRaWAN!')
    # create a LoRa socket
    # set the LoRaWAN data rate
    lora.callback(trigger=(LoRa.RX_PACKET_EVENT), handler=lora_cb)
    # loop for class C
    # make socket non-blocking
    s.setblocking(False)
    print('waiting...')
        time.sleep(1.5)
    # loop for class A
    # make the socket blocking
    # (waits for the data to be sent and for the 2 receive windows to expire)
        s.setblocking(True)
    # send some data
        print('sending data')
        s.send(bytes([0x01, 0x02, 0x03]))
    # (because if there's no data received it will block forever...)
    # get any data received (if any...)
        data = s.recv(64)
        print("<<",data)
        time.sleep(15)
  • @raxy I am very interested, please share (-;
  • guys,
    with the help of Nicolas C. from objenious,
    I can now join their network with my LopY , both in class A and.... in class C!
    I can do uplinks and get asynchronous downlinks using a callbac in class C and in micropython.
    I'll share how I did that, if anyone is interested
  • Has any of us managed to connect a LoPy to the Objenious LoRaWAN network?
    I can't.
    With the example LoRaWAN OTAA join method code, using proper app EUI and app key doesn't allow me to join the network. Besides, there is no event raised when the handshake is made, how would you debug the join failure? I have tried my own approach to join, tuning parameters such as bandwith, coding rate and spreading factor, nothing seems to do the trick.
    Any idea?
  • the lopy came from objenious and they said it should work on their network; they just recommended to flash the latest firmware (for doing class C);
    they are in the process of delivering me all the keys to use upon join; for now , the lopy pretends to be another device (already fully registered and working but powered off)
  • @Jurassic-Pork
    Sounds like those guys don’t understand the whole point of LoRa is you shouldn’t need agreements to connect any - LoRa compatible and especially certified - device to a network.
    Just my opinion but I’d be scared about putting my business on such a network, thry’ll just get in the way at every corner.
  • hello raxy ,
    here is the answer of objenious for my request :
    Nous sommes en train de mettre en place des accords avec Pycom pour ajouter la connectivité Objenious avec les modules Pycom.
    Je vous invite à recontacter Pycom pour bénéficier de la connectivité en plus des modules.
    Bien cordialement,
    Guillaume TRANIER | Chef de projet partenariat
    20 rue Troyon, 92310 Sèvres | gtranier@objenious.com
    but no news of those agreements from pycom.
  • i also leave in paris and want to connect my pycom to objenious infrastructure; i have a company account there,
    for now , i cannot even be seen by their spot admin web interface trying to join their network, i do not know why yet
  • Without having hands-on experience with the network, in theory: yes. The objenious network uses LoRa, you probably just need an account and an online environment to create the correct keys (similar like you do with TTN) to add in the configuration of the LoPy.
    If I want to switch my LoPy from TTN to the Dutch commercial KPN network, it literally is just a matter of changing the AppSKey, the Device address and the Device EUI in the config.py file and resetting the node.
    I looks like someone has been experimenting with the LoPy on objenious and had some problems specific to the network. See this post. Maybe he can give (you) an update on how stable the network is now?
    (and then you can post it here again so others can find that info more easily also)
Hello World?
Back Us On Kickstarter >
