Lora-Mac=FFFFFFFFFFFFFFFF
The Lora MAC is actually stored in flash memory. You can set it by uploading an 8 byte binary file containing your MAC address as /flash/sys/lpwan.mac (see github source)
Try running the following code directly on your LoPy to generate the file (make sure to use a unique MAC address):
fo = open("/flash/sys/lpwan.mac", "wb") mac_write=bytes([0x01,0xb1,0xd1,0x41,0x91,0x31,0xb1,0xb4]) fo.write(mac_write) fo.close()Then reset your LoPy... you should see the following message during boot on the serial console:
LPWAN MAC write OKLet me know if this works for you
@Xykon That's work !! :-) thanks a lot
@Xykon Thanks
@daniel For a custom firmware is always FFFFFFFFFFFF. There is some build parameter to get the mac as you have for official firmware? How we can set up the mac?
My lora mac ID changed after [v1.20.0.rc13] Release Candidate firmware update of my Lopy4?
I used the code above to change it back to the original mac ID.I also did the firmware udpate on another Lopy4 but I didn't notice a connecton problem there.
@Xykon Hi, how could I make sure I am using an unique MAC?, thanks
