    Has anyone successfully used lora.nvram_save() and restore?
    lopyloranvram
    17 Posts 7 Posters 5.0k Views 9 Watching
      jalperin
      Re: How to accomplish lora.nvram_restore() ?
      I have tried many variations, but no luck for me. If anyone has been successful, would you please post your code?
        jmarcelino
        Yes it's working and really simple.
        First time you do your normal join (you do need to wait until it has actually joined!) then
        lora.nvram_save()
        Afterwards do
        s.send(bytes([0x01, 0x02, 0x03]))
          jalperin
          Thank you, jmarcellino. That is, I think, what I am doing, but without success. Below is my code. I get the first message, but not the second. I have check my gateway. It only sees the first message.
          from network import LoRa
          import struct
          import binascii
          import math
          from pysense import Pysense
          py = Pysense()
          loraSaved = pycom.nvs_get('loraSaved')
          if not loraSaved:
          freq = 902300000
          for channel in range(0, 72):
          lora.remove_channel(channel)
          for chan in range(0, 8):
          lora.add_channel(chan, frequency=freq, dr_min=0, dr_max=3)
          dev_addr = struct.unpack(">l", binascii.unhexlify('*****21E27'))[0]
          nwk_swkey = binascii.unhexlify('************4BD956A16FF3DADEB05608C1')
          app_swkey = binascii.unhexlify('*************738855C61661D0FF27')
          while not lora.has_joined():
          machine.idle()
          s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
          s.setblocking(False)
          s.send('LoRa Up')
          time.sleep(2)
          lora.nvram_save()
          pycom.nvs_set('loraSaved', 1)
          py.setup_sleep(60)
          py.go_to_sleep()
          s.send('LoRa Restored')
          time.sleep(2)
          pycom.nvs_set('loraSaved', 0) # reset for next test
          J 2 Replies Last reply Reply Quote 0
            jmarcelino @jalperin
            @jalperin
            Umm so differences I see is I'm using OTAA and on EU868 region while you use ABP in the US915 region... also I do a few app related things before sending data and send several packets.
            Try s.setblocking(True) for your sends and also try more than one send, maybe a loop sending 10.
              @jalperin
              Try to restore your channel frequency configuration manually again after the nvram_restore, just use your existing code:
              The current nvram_save() may not save this...
              J B 2 Replies Last reply Reply Quote 0
                jalperin @jmarcelino
                @jmarcelino
                Restoring the channel configuration did the trick. Setblocking(True) was not needed here.
                An anomaly that I have seen before showed up. The packets sent after nvram_restore all arrived with "payload not provided". But, if I first send a packet with a payload of a single character, it and all subsequent packets arrive successfully.
                May I suggest that the documentation be amended to detail what is and is not saved by lora.nvram_save().
                Thank you very much for your help.
                  johncaipa @jalperin
                  @jalperin @jmarcelino works but the counter is restarted on each send, this value is not stored?
                  bmarkusB 1 Reply Last reply Reply Quote 0
                  • bmarkusB Offline
                    bmarkus @johncaipa
                    @johncaipa said in Has anyone successfully used lora.nvram_save() and restore?:
                    Unfortunately it is not possible to get or set your own FCnt value, otherwise it would be possible to handle in your code. Just one of the several missing LoRa/LoRaWAN functions.
                      johncaipa @bmarkus
                      @bmarkus in the documentation says that this value is saved, then I do not know what would be the problem, because in each sending after waking up the packet counters is always in 1 on TTN.
                      "lora.nvram_save()
                      Save the LoRaWAN state (joined status, network keys, packet counters, etc) in non-volatile memory in order to be able to restore the state when coming out of deepsleep or a power cycle."
                      • bmarkusB Offline
                        bmarkus @johncaipa
                        "lora.nvram_save()
                        Do you create a new instance when coming out? It resets the counter.
                          johncaipa @bmarkus
                          @bmarkus this is the example code I'm testing, based on which share @jalperin, I'm missing something?
                          import struct
                          import binascii
                          import math
                          py = Pysense()
                          print(loraSaved)
                          if not loraSaved:
                          freq = 902300000
                          dev_addr = struct.unpack(">l", binascii.unhexlify('************'.replace(' ','')))[0]
                          nwk_swkey = binascii.unhexlify('************ 89 F1 74 79 40'.replace(' ',''))
                          app_swkey = binascii.unhexlify('************ 3A AA BD E8 A9'.replace(' ',''))
                              machine.idle()
                          s.bind(3) #select the port number
                          s.send('LoRa Up')
                          time.sleep(2)
                          lora.nvram_save()
                          py.setup_sleep(60)
                          py.go_to_sleep()
                          freq = 902300000
                          time.sleep(2)
                          lora.nvram_save()
                          #pycom.nvs_set('loraSaved', 0) # reset for next test
                          py.setup_sleep(60)
                          py.go_to_sleep()
                          • R Offline
                            rloro338
                            I am trying to use lora.nvram_save() and lora.nvram_restore() and not works. I set all parameters (LoRaWAN, adr = True, app_eui, app_key and channel configuration) the first time that I boot the device and send a message Loriot server receive it. Then device go to deepsleep for 5 seconds and restore the join state. If I look the state with lora.has_joined() return True value, but when I trying to send the message it isn't received by the gateway.
                            It is curious because when I use the node directly with a command line in Putty the restore and save comands works fine.
                            What I am doing wrong??
                              johncaipa @rloro338
                              @rloro338 I made the following changes to my code and now it works correctly:
                              • list item make sure the socket is blocking ( s.setblocking(True) )
                              • list item add a time.sleep(2) after sending, before saving and going to deep sleep.
                              • B Offline
                                Bismarck501 @jmarcelino
                                @jmarcelino Hello, I have read your suggestion carefully and tried in my project. But there was some issues about this solution.
                                My device consists of FiPy+pysense, and I connected to TTN via OTAA. My code with lora,nvram_save() and restore() is:
                                # pysense sensor part
                                from LTR329ALS01 import LTR329ALS01
                                from LIS2HH12 import LIS2HH12
                                # FiPy part
                                import ubinascii
                                # pysense machine part
                                from machine import RTC
                                from machine import SD
                                import os
                                from network import WLAN, Bluetooth,LTE
                                # set parameters for sensor function
                                py = Pysense()
                                lt = LTR329ALS01(py)  # only use light sensor
                                loraSaved = pycom.nvs_get('loraSaved')  # if join already, it is int 3; or it will be None
                                #-------------------------------- if already join -------------------------------------#
                                if (loraSaved == 11):
                                    lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
                                    #--------- Remove default channels ----------#
                                    for index in range(0, 15):
                                        lora.remove_channel(index)
                                    lora.add_channel(3, frequency=867100000, dr_min=0, dr_max=5)
                                    lora.add_channel(4, frequency=867300000, dr_min=0, dr_max=5)
                                    lora.add_channel(5, frequency=867500000, dr_min=0, dr_max=5)
                                    lora.add_channel(6, frequency=867700000, dr_min=0, dr_max=5)
                                    lora.add_channel(7, frequency=867900000, dr_min=0, dr_max=5)
                                    lora.add_channel(8, frequency=868100000, dr_min=0, dr_max=5)
                                    lora.add_channel(9, frequency=868300000, dr_min=0, dr_max=5)
                                    lora.add_channel(10, frequency=868500000, dr_min=0, dr_max=5)
                                    lora.add_channel(11, frequency=868700000, dr_min=0, dr_max=5)
                                    lora.add_channel(12, frequency=868900000, dr_min=0, dr_max=5)
                                    lora.add_channel(13, frequency=869100000, dr_min=0, dr_max=5)
                                    lora.add_channel(14, frequency=869300000, dr_min=0, dr_max=5)
                                    lora.add_channel(15, frequency=869500000, dr_min=0, dr_max=5)
                                    print("Join already")
                                    #						Set LoRa parameters
                                    # create a LoRa socket
                                    # set the LoRaWAN data rate
                                    #---------- Send uplink & Stroe uplink data ----------------#
                                    uplink_payload = ("Light: " + str(lt.light()))
                                    s.setblocking(True)
                                    s.send(uplink_payload)
                                    lora.nvram_save()
                                    print("send finish")
                                    #--------- Receive downlink & Stroe downlink data ----------#
                                    downlink_message = s.recv(64) # bytes form     and     n is typically < 64 bytes
                                    print(downlink_message)
                                    print(type(downlink_message))
                                    print("Receive finish")
                                    #----------- Jugde whether there is a downlink -------------#
                                    if downlink_message == b'':
                                        print("There is no downlink")
                                        downlink_payload = downlink_message.decode('ascii') # string form
                                        print("Downlink message: " + downlink_payload)
                                        #-------- Judge downlink message & operate -------------#
                                        if downlink_message == b'2': # if ==2, it will light green for 5 seconds
                                            print("Hi, Green!")
                                            time.sleep(3)
                                        if downlink_message == b'4': # if ==4, it will light yellow for 5 seconds
                                            print("Hi, Yellow!")
                                            pycom.rgbled(0x7f7f00) # yellow
                                            time.sleep(3)
                                    print("####################################")
                                    print("\n")
                                #-------------------------------- if never join before -------------------------------------#
                                    print("Firstly join")
                                    # 					Initialise LoRa in LORAWAN mode.
                                    #				Set OTAA mode and connect with the gateway
                                    # create an OTAA authentication parameters
                                    app_eui = ubinascii.unhexlify('70B3D57ED0013E78')
                                    app_key = ubinascii.unhexlify('5D87FAB0BC66A45FB0DA07453ED2BC2B')
                                    # join a network using OTAA (Over the Air Activation)
                                    # wait until the module has joined the network
                                        time.sleep(2.5)
                                        print('Not yet joined...')
                                    # join in
                                    print('Successfully join in!')
                                    s.setblocking(True)
                                    lora.nvram_save()
                                    #time.sleep(1)
                                            print("Hi, Green!")
                                            time.sleep(3)
                                            time.sleep(3)
                                    print("\n")
                                    #---------- store in flush to judge next time ----------------#
                                    pycom.nvs_set('loraSaved', 11)
                                # time sleep
                                py.setup_sleep(9)   # setup a 9 seconds sleep time
                                py.go_to_sleep()
                                And it can work well. However, after one day, when I tried again, there would be an issue when running code at line 65:
                                Where I was wrong? Thanks for giving me some advice!
                                  jcaron @Bismarck501
                                  @Bismarck501 You should factorise your code a lot, it would make things a lot easier to maintain.
                                  You shouldn't rely on an additional NVRAM variable to determine your LoRaWAN state.
                                  Instead, just call nvram_restore, then has_joined. If not true, you need to join. Otherwise, you can go ahead and send/receive.
                                  Also, I would call nvram_save after any interaction with the LoRaWAN stack is finished including the recv part. Not sure it currently causes any issues, but it's better to be consistent.
                                  • B Offline
                                    Bismarck501 @jcaron
                                    @jcaron Thanks for responsing so quick! I have tried your suggestion and it works now. And I will experiment further to eusure the stability. Now the code is:
                                    # FiPy part
                                    import ubinascii
                                    import os
                                    py = Pysense()
                                    lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)   # itialise LoRa in LORAWAN mode.
                                    if not lora.has_joined():
                                        #-------------------- use OTAA to connect with TTN ------------------------------#
                                        lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0) # join a network using OTAA (Over the Air Activation)
                                        while not lora.has_joined():    # wait until the module has joined the network
                                            time.sleep(2.5)
                                        # join in
                                        #---------- Set LoRa parameters ----------------#
                                        s.setblocking(True)
                                        #time.sleep(1)
                                        lora.nvram_save()   # store in flush to judge next time
                                                print("Hi, Green!")
                                                time.sleep(3)
                                                pycom.heartbeat(True)
                                                time.sleep(3)
                                        print("\n")
                                        #---------------------------Set LoRa parameters-------------------------------------#
                                        s.setblocking(True)
                                        lora.nvram_save()
                                                print("Hi, Green!")
                                                time.sleep(3)
                                                time.sleep(3)
                                        print("\n")
                                    print("Deep sleep begin!")
                                    # time sleep
                                    py.setup_sleep(9)   # setup a 10 seconds sleep time
                                    py.go_to_sleep()
                                    #machine.deepsleep(9000)  # machine.deepsleep([milli_sec])
                                    Thanks a lot!
                                    • B Offline
                                      Bismarck501 @jcaron
                                      @jcaron The issue has been worked out and it works quite well now! Thanks a lot!
