LoPy - USB - Pymakr getting started
  • I am using a LoPy on the Atom pymakr plug in in OSX 10.12.5 and (connecting via USB) everything is connecting but after it connects, the ">>>" is not showing. To force the console to show ">>>" I can hit run or get serial ports and that does it. But once the ">>>" is showing I cannot type at all into the console and running a test program that just writes to the console does not write either.
    Am I missing a step and what can I do to fix this? Thanks for your help.
  • OP Here
    I also uninstalled atom and pymakr a couple of times. I also uninstalled pymakr a third time and installed using apm install and that did not work.
