FTP while waiting (blocked) for Lora message
With FileZilla I can list folders and files while the LoPy waits blocked for a LoRa message. But I cannot get a file until the program has stopped. The LoPy is connected to my local WiFi. The file shall be closed. FileZilla is waiting for a connection until it gets a timeout.
lora = LoRa(mode=LoRa.LORA, frequency=863000000)
s.setblocking(True)
line = s.recv(255)
f = open('/sd/test.log', 'a')
f.write(line)
f.write('\n')
f.close()
}Issue occurs on firmware 1.8 and 1.9.
Missing a code formatter in the forum, so I used {} to mark the loop block ;) -
@crumble The code formatter is three backquotes (```) on a single line.
Did you set Filezilla to using a single session only. That is not possible in fast connect. You have to use the server configuration (Ctrl-S). -
@robert-hh
Thank you, I forgot to limit the connections
