    Function similar to Pulse In in C
    lopyerror
    27 Posts 4 Posters 9.1k Views 4 Watching
      robert-hh @soren
      @soren Testing with a frequency generator, square wave, I found a bug in pulses_get. If you go down below 25 Hz (= 20000us pulse duration), the pulse counter locks. Even raising the frequency again does not help, only hard reset. 26Hz is the slowest you can take. looking at the light sensor, this is bad, because the dark frequency is at about 10 Hz.
      That behavior can be cured by changing the source code, mods/modpycom.c, line 107, into:
      rmt_rx.rx_config.idle_threshold = 0xffff;
      Then, the maximum timeout value is about 65000, the lowest frequency with reasonable values is 16 Hz (or 32 ms pulse duration). Going below that gives you bad values, but once you're above that threshold, the device works again as expected without the need for a reset.
      sorenS D 2 Replies Last reply Reply Quote 2
      • sorenS Offline
        soren @robert-hh
        @robert-hh
        Very good to know! I doubt this sensor will go down into frequencies that low though. And actually, getting many samples from pulses_get is pretty neat since I need to get an average value anyway. So, so far I'm very optimistic. Still some way to completely getting correct results and understanding them.
        And thanks for the microseconds tip, obviously pulses_get timeout should be 1000 then.
        Here's a snippet of my data output. This is with red filter activated (s2 and s3 held low). Bold values are before I put a completely red book over the sensor (very close):
        305.0
        345.0
        305.875
        308.625
        311.25
        296.1667
        291.1666
        208.2
        201.9
        206.7
        206.2
        209.6
        196.1
        179.0
        Strange thing is how the values go down after putting the red book over. Maybe it's inverse. I'll probably have to read more up on the concepts of it to get it. Currently trying to grasp this: https://arduinoplusplus.wordpress.com/2015/07/15/tcs230tcs3200-sensor-calibration/ not
        EDIT: aaah, just realised that the data looks fine. As a period gets shorter, obviously frequency gets higher. Shoot me.
        Code:
            oe.value(0)
            oeTimer = OETIMER()
            data = pulses_get(sout, 1000)
            del data[-1] # delete last element
            del data[0] # delete first element
            sum = 0
            for trans in data:
                sum += trans[1]
            avr = sum / len(data)
            print(avr)
        EDIT II:
        Hmm, after converting from period to frequency, I still get some strange results. Eg, when holding up a (very) red book - the sensor will read RGB frequencies like this one: [3086.42, 6038.647, 3100.775] This is in hertz, and I found it weird that the red channel isn't relatively higher than the other ones. I'm doing calculation and conversion like this:
        s2Array = [0, 0, 1] # arrays for setting color filters on sensor
        s3Array = [0, 1, 1]
            rgbArray = [0, 0, 0]
            for num in range(0, 3):
                s2.value(s2Array[num]) # set colour filters
                s3.value(s3Array[num])
                time.sleep_ms(1)
                oe.value(0)
                oeTimer = OETIMER() # set timer to turn off sensor
                data = pulses_get(sout, 1000) # get period values
                if len(data) == 0:
                    print('no data collected. breaking.')
                    break
                sum = 0
                for trans in data:
                    sum += trans[1]
                avrPeriodUs = sum / len(data) # average period in micro seconds
                avrPeriodSec = avrPeriodUs / 1000000 # convert to seconds
                avrFreq = 1 / avrPeriodSec # get frequency
                #print(num, ' ', avrFreq)
                rgbArray[num] = avrFreq
            print(rgbArray)
          Devang Sharma @robert-hh
          @robert-hh As you mentioned about the changes made in modpycom.c, does it mean that pulses_get() can be used for PWM of more than 32ms??
          Thanks,
          Devang
            robert-hh @Devang Sharma
            @devang-sharma No. pulses_get() uses 16 bit counters of a 1 MHz clock. The high bit is ignored, so you get effectively results only for pulses shorter than 32ms. The change only prevents, that the counter stalls if by chance longer pulses arrive. I did not dig further yet to see, if the counter can be set to lower input frequencies. But since pulses_get uses the remote control circuit, intended for signal frequencies of 20-50 kHz, the chances may be odd.
              Devang Sharma
              @robert-hh,
              I've been trying to write a code which can function as pulses_get() but can detect higher pulse width. I used Nova SDS011 Dust sensor.
              This is my main.py file:
              from trig import *
              from machine import Pin
              from machine import Timer
              trig = TRIG()
              chrono = Timer.Chrono()
              chrono.start()
                  if pin1() == 1:
                      trig.high1()
                  if pin2() == 1:
                      trig.high2()
              This is my library file trig.py:
              from machine import PWM
              pin1 = Pin("G9", mode = Pin.IN, pull = Pin.PULL_UP) # PM2.5
              pin2 = Pin("G8", mode = Pin.IN, pull = Pin.PULL_UP) # PM10
              class TRIG:
                  def __init__(self, prev1=0, prev2=0, pulse1=0, pulse2=0, dust25=0.0, dust10=0.0):
                      self.prev1 = prev1
                      self.prev2 = prev2
                      self.pulse1 = pulse1
                      self.pulse2 = pulse2
                      self.dust25 = dust25
                      self.dust10 = dust10
                  def low1(self):
                      if pin1.value() == 1:
                          self.high1()
                      self.pulse1 = time.ticks_diff(self.prev1, time.ticks_us())
                      print("Pulse1: ", self.pulse1)
                  def low2(self):
                      if pin2.value() == 1:
                          self.high2()
                      self.pulse2 = time.ticks_diff(self.prev2, time.ticks_us())
                      print("Pulse2: ", self.pulse2)
                  def high1(self):
                      if pin1.value() == 0:
                          self.low1()
                      self.prev1 = time.ticks_us()
                  def high2(self):
                      if pin2.value() == 0:
                          self.low2()
                      self.prev2 = time.ticks_us()
                  def getdata(self):
                      if self.pulse1 >= 2000:
                          self.dust25 = float((self.pulse1 - 2000)/1000)
                      if self.pulse2 >= 2000:
                          self.dust10 = float((self.pulse2 - 2000)/1000)
                      print("DUST PM2.5: ", self.dust25)
                      time.sleep_us(500)
                      print("DUST PM10 : ", self.dust10)
                      time.sleep_us(500)
              Right now, I'm not calling getdata() function. I'm only trying to measure pulse width. While doing that, I get the output as below:
              This received output is in Microseconds. That means that the frequencies are around 4-5kHz. Received data is either wrong or again this is some of the limitations of LoPy! I'm confused! What is the issue here? Is there any solution?
              Also, I've read about time.ticks_diff() in docs, which says:
              Measure period between consecutive calls to ticksms(), ticks_us(), or ticks_cpu(). The value returned by these functions may wrap around at any time, so directly subtracting them is not supported. ticks_diff() should be used instead. “old” value should actually precede “new” value in time, or result is undefined. This function should not be used to measure arbitrarily long periods of time (because ticks() functions wrap around and usually would have short period).
              Does this also say about the limitations?
              Thanks,
              Devang
                @devang-sharma Ticks_us uses a 32 bit counter, which starts after reset and wraps around after 2**32 microseconds or about 71 minutes. But there is a bug in ticks_diff(), such that about 36 minutes after reset numbers received from tick_us() will raise an exception when fed into tick_diff(). But since you do not get an exception, this should not be your problem. I glanced at your code, but I'm wondring why you do not use the edge triggered interrupts of the PIN handler by pin.callback(trigger, handler=None, arg=None). Use that to
                a) register a pair of handlers for rising and falling events,
                b) memorize the time at a rising edge, set a busy flag and
                c) get the difference at a falling edge, put it into a place for results, e.g. a list, and clear the busy flag.
                or the like. Synchronization may be a little bit tricky.
                Pitfalls:
                a) There is a latency of a few 100 µs for all kind of interrupts. That will have an impact at low readings.
                b) The esp32 might create false triggers if the slope of the input signal is too slow. The datasheet is silent about that. So you might have to double check in your code in the handler, is the state is as expected, e.g. if after a falling slope the level is indeed low.
                L D 2 Replies Last reply Reply Quote 1
                  livius @robert-hh
                  @robert-hh said in Function similar to Pulse In in C:
                  because it cast to small int and i do not understand the comment that this is "as designed cast"
                  STATIC mp_obj_t time_ticks_diff(mp_obj_t t0, mp_obj_t t1) {
                      // We want to "cast" the 32 bit unsigned into a 30-bit small-int
                      uint32_t start = mp_obj_get_int(t0);
                      uint32_t end = mp_obj_get_int(t1);
                      return MP_OBJ_NEW_SMALL_INT((end - start) & MP_SMALL_INT_POSITIVE_MASK);
                    @robert-hh Thanks for the help. I tried using pin.callback().
                    main.py :
                    from trig import *
                    trig = TRIG()
                    chrono.start()
                        # if pin1() == 1:
                        #     trig.high1()
                        # if pin2() == 1:
                        #     trig.high2()
                        # if int(chrono.read()) >= 60:
                        #     trig.getdata()
                        time.sleep_ms(500)
                        pin1.callback(Pin.IRQ_RISING, trig.high1())
                        time.sleep_ms(500)
                        pin2.callback(Pin.IRQ_RISING, trig.high2())
                    trig.py :
                    class TRIG:
                        def __init__(self,flag1=0, flag2=0, prev1=0, prev2=0, pulse1=0, pulse2=0, dust25=0.0, dust10=0.0):
                            self.flag1 = flag1
                            self.flag2 = flag2
                            self.prev1 = prev1
                            self.prev2 = prev2
                        def low1(self):
                            # pin1.callback(Pin.IRQ_RISING, self.high1())
                            # if pin1.value() == 1:
                            #     self.high1()
                            if self.flag1 == 1:
                                self.flag1 = 0
                            # self.getdata()
                        def low2(self):
                            # pin2.callbck(Pin.IRQ_RISING, self.high2())
                            # if pin2.value() == 1:
                            #     self.high2()
                            if self.flag2 == 1:
                                self.flag2 = 0
                            # self.getdata()
                        def high1(self):
                            self.flag1 = 1
                            pin1.callback(Pin.IRQ_FALLING, self.low1())
                            # if pin1.value() == 0:
                            #     self.low1()
                        def high2(self):
                            self.flag2 = 1
                            pin2.callback(Pin.IRQ_FALLING, self.low2())
                            # if pin2.value() == 0:
                            #     self.low2()
                        def getdata(self):
                            time.sleep_us(500)
                            time.sleep_us(500)
                    Output:
                    Pulse1: 120
                    Pulse2: 106
                    Pulse1: 107
                    Pulse2: 106
                    Pulse1: 93
                    Pulse2: 93
                    Pulse1: 107
                    Pulse2: 120
                    Pulse1: 106
                    Pulse2: 93
                    Pulse1: 94
                    Pulse2: 107
                    Pulse1: 107
                    Pulse2: 106
                    Pulse1: 107
                    Pulse2: 106
                    Why I get so short pulses?
                      robert-hh @livius
                      @livius The snippet you show is not used by utime.ticks_diff(). The one used is in esp32/mods/modutime.c
                      STATIC mp_obj_t time_ticks_diff(mp_obj_t start_in, mp_obj_t end_in) {
                         uint32_t start = mp_obj_get_int(start_in);
                         uint32_t end = mp_obj_get_int(end_in);
                         return mp_obj_new_int_from_uint((end - start));
                      STATIC MP_DEFINE_CONST_FUN_OBJ_2(time_ticks_diff_obj, time_ticks_diff);
                      The problem is, that tick_us() returns unsigned 32 bit values, which do not fit into a short int and fail in ticks_diff() when they should be converted to an int. There are implementations of the functions in extmod/mphal_utime.c, which work. Alternatively, I use the following patch for ticks_diff()
                          int32_t start = mp_obj_get_int_truncated(start_in);
                          int32_t end = mp_obj_get_int_truncated(end_in);
                          return mp_obj_new_int((end - start));
                      Which takes just the lower bits of the int. That would even allow ticks_us and tick_ms to return 64 bit values, reducing the chance of an overflow substantially (overflow of tick_us() after about 584542 years).
                        @devang-sharma I'll look into that tonight. I need a test set-up for that.
                          livius @robert-hh
                          @robert-hh
                          Yes, i digged in wrong place..
                            @devang-sharma I got a little bit lost by your code, so I made one by myself, which works at least with the function generator. The times shown ar a little bit shorter than what I set-up at the function generator, like 899 instead of 900, but mostly right.
                            import utime
                            class Pulses:
                                def __init__(self, p10_name, p25_name):
                                    self.result_p10 = None
                                    self.result_p25 = None
                                    self.start_p10 = None
                                    self.start_p25 = None
                                    if p10_name is not None:
                                        self.pin_p10 = machine.Pin(p10_name, machine.Pin.IN, pull = machine.Pin.PULL_UP)
                                        self.pin_p10.callback(machine.Pin.IRQ_RISING | machine.Pin.IRQ_FALLING, self.trig_p10)
                                    if p25_name is not None:
                                        self.pin_p25 = machine.Pin(p25_name, machine.Pin.IN, pull = machine.Pin.PULL_UP)
                                        self.pin_p25.callback(machine.Pin.IRQ_RISING | machine.Pin.IRQ_FALLING, self.trig_p25)
                                def trig_p10(self, pin):
                                    if self.pin_p10.value() == 1:
                                        self.start_p10 = utime.ticks_us()
                                    elif self.start_p10 is not None:
                                        self.result_p10 = utime.ticks_diff(self.start_p10, utime.ticks_us())
                                def trig_p25(self, pin):
                                    if self.pin_p25.value() == 1:
                                        self.start_p25 = utime.ticks_us()
                                    elif self.start_p25 is not None:
                                        self.result_p25 = utime.ticks_diff(self.start_p25, utime.ticks_us())
                                def get_p10(self):
                                    if self.result_p10 is None:
                                        return None
                                        result = self.result_p10
                                        return result
                                def get_p25(self):
                                    if self.result_p25 is None:
                                        return None
                                        result = self.result_p25
                                        return result
                                def stop(self):
                                    self.pin_p10.callback(machine.Pin.IRQ_RISING | machine.Pin.IRQ_FALLING, None)
                                    self.pin_p25.callback(machine.Pin.IRQ_RISING | machine.Pin.IRQ_FALLING, None)
                            pulses = Pulses("G9", "G8")
                            try:
                                    res = pulses.get_p10()
                                    if res is not None:
                                        print ("DUST PM10:  {:<6.1f}".format(res/1000))
                                    res = pulses.get_p25()
                                    if res is not None:
                                        print ("DUST PM2.5: {:<6.1f}".format(res/1000))
                                    utime.sleep_ms(10)
                            except KeyboardInterrupt:
                                pulses.stop()
                                print ("Test stopped")
                              @robert-hh Thanks a lot, Man! Works like a charm. :) Now I get where I was wrong! I was measuring pulses the wrong way. Moreover, I wasn't resetting the self.start variable..!! :'D
                              Thank You,
                              Devang.
                              • 1
                              • 2
                              • 2 / 2
