LoPy L01 LoRaWAN blocking socket.send() hangs permanently
  • Using firmware v1.10.2.b1 on LoPy L01 OEM module
    Using the code shown below periodically the socket.send() function call hangs forever. The only way to recover is to enable the watchdog timer.
    Code:
    import network
    from network import LoRa
    import binascii
    reset_cause = machine.reset_cause()
    def select_subband(lora, subband):
        if (type(subband) is int):
            if ((subband<1) or (subband>8)):
                raise ValueError("subband out of range (1-8)")
            raise TypeError("subband must be 1-8")
        for channel in range(0, 72):
            lora.remove_channel(channel)
        channel_idx = 0
        for channel in range((subband-1)*8, ((subband-1)*8)+8):
            lora.add_channel(channel_idx, frequency=902300000+channel*200000, dr_min=1, dr_max=3)
            channel_idx += 1
    # Initialize LoRa in LORAWAN mode.
    print("LoRa init")
    lora = LoRa(mode=LoRa.LORAWAN, device_class=LoRa.CLASS_A)
    if reset_cause == machine.DEEPSLEEP_RESET:
        lora.nvram_restore()
    if reset_cause == machine.DEEPSLEEP_RESET and lora.has_joined():
        print('Skipping LoRaWAN join, previously joined')
        select_subband(lora, 1)
        # create an OTAA authentication parameters
        app_eui = binascii.unhexlify('00 00 00 00 00 00 00 01'.replace(' ',''))
        app_key = binascii.unhexlify('00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01'.replace(' ',''))
        # join a network using OTAA (Over the Air Activation)
        print('Joining LoRa network')
        # wait until the module has joined the network
        while not lora.has_joined():
            time.sleep(2.5)
        print('Joined!!!')
    # create a LoRa socket
    print("LoRa socket setup")
    s.setsockopt(socket.SOL_LORA, socket.SO_DR, 1)
    s.setblocking(False)
    print("Init complete, running main loop")
    # simulate time delay to detect sensors, etc
    time.sleep(10)
        was_lora_tx_error = False
        try:
            s.setblocking(True)
            print('Trying to send...')
            s.send(bytes(21))
            print('info sent')
        except Exception as e:
            was_lora_tx_error = True
            if e.args[0] == 11:
                print('cannot send just yet, waiting...')
                time.sleep_ms(30)
                print('error: ')
                print(e.args[0])
                raise    # raise the exception again
        if not was_lora_tx_error:
            print('Going to deep sleep')
            time.sleep_ms(10)
            lora.nvram_save()
            lora.power_mode(LoRa.SLEEP)
            machine.deepsleep(10000)
  • @mechatron
    Thanks for the report. I recorded it below and we’ll look into it
    https://github.com/pycom/pycom-micropython-sigfox/issues/105
