    LoPy Nano-Gateway
    62 Posts 27 Posters 52.0k Views 31 Watching
    • F Offline
      Feiko @borjam
      The distance and the power do not seem to be the problem. I tried running the test over 100 meters. If I put a time.sleep(0.2) after lora_sock.recv(512) and lora_sock.send(pkg) on both server side and client side, the code runs. In previous firmware the code run straight out of the box. I think the OSError:[Enro 11] is caused by a cue in the send buffer. Sometimes there are still receive messages left in the buffer, even after a soft reset. I use the code
      recv_dumpbuffer = lora_sock.recv(512)
      time.sleep(0.2)
      to make sure the receivebuffer is empty.
      the 200ms waits in between Lora commands are hardly ideal. On previous firmware versions the code run straight out of the box.
      • F Offline
        Feiko
        Just run the Nano-Gateway with the latest firmware 1.3.0.b1. All problems are resolved :D. Thanks Pycom team.
          gouao
          • M Offline
            microman7k
            On "Nano-Gateway" with the latest firmware 1.3.0.b1 i'm still getting "ValueError: buffer too small" after hour of two running posted sample code. Is this problem with the sample code or is it firmware problem?
              gouao
              • F Offline
                FelixDonkers @gertjanvanhethof
                @gertjanvanhethof I'm also interrested to use LoPy as a LoRaWan gateway. Looking forward to a solution.
                  Colateral @Roberto
                  @Roberto We setup a test bench with 3 LoPy following the idea of your code. We did the test with blocking socket and thread and non blocking sockets. The result is the same.
                  2 are the nodes configured as tx_iq and and one is the Gw (rx_iq).
                  The script is simple: each device (node and GW) is sending 29 bytes message size (_MSG_FORMAT = "!HHLBB%ds") each 2 seconds. In the msg data we are printing a counter (that varies from device). That counter is also in the header (see above)
                  We noticed that sometimes if you start the gw after the nodes... randomly some of the nodes are not receiving the data, despite the fact the GW is receiving the data from the nodes. And we observed also that sometimes when we start the node after the GW, the GW is not receiving the data from the nodes.
                  You need to reset the node or GW in order to get the broadcasted data from to the others... and this hazardous and not at all good in real deployment.
                  BUT THE MOST PROBLEMATIC is the fact that the 29bytes are partially received, sometimes you are getting 15bytes or whatever number less than 29bytes.
                  Have you experience this connection issue related with nodes/gw starting order?
                  Does LoPy stack is guarantee the receiving of msg in one chunk? ( if you send 29bytes you got 29bytes)
                  Here are some samples:
                  good msg receive
                  to: 0
                  Flags: 0
                  PayloadSize: 18
                  Payload: b'3058- 1234567890 '
                  <<< beat msgId 3066
                  bufferSize 29
                  pkgSize 28
                  data_size 18
                  remaining buffer 0
                  bad msg receive
                  to: 0
                  Flags: 0
                  PayloadSize: 18
                  Payload: b'3059- 1234567890 '
                  bufferSize 15
                  buffer too small <<< ustruct exception
                  • R Offline
                    Roberto @Colateral
                    Hi @Colateral,
                    Yes, i have noticed that sometimes some messages arrive malformed or with bytes missing. This could be due to LoRa message collision between devices. If two devices send at the same time in the same band this can happen.
                    There is a new blog here in the forum with a new code suggestion that includes.
                    1. Message length check on the nano-gateway
                    2. Message retry on the nodes
                    3. Max timeout in the nodes
                    Number 3 will help with the fact that you have to have the nano-gateway on before you start the nodes. In this code, after sending a message the node waits in an infinite loop for the ack. The problem with this approach is that if no ack is received (the nano-gateway was not connected yet) the node will stay in that loop until reseted.
                    Keep in ming that both this and the new code are just examples for specific usages and they require adaptation depending on your needs.
                    The link for the new post is LoPy Nano-Gateway Extended (Timeout and Retry)
                    Best,
                    Roberto
                    • F Offline
                      feabhas @Roberto
                      @Roberto I have successfully got a 2 node and 1 gateway setup working based on your code, thanks very much. One minor query, In the gateway you use
                      _LORA_PKG_FORMAT = "!BB%ds"
                      but in the node_1.py you miss off the !, e.g.
                      _LORA_PKG_FORMAT = "BB%ds"
                      Shouldn't they be consistent?
                      • R Offline
                        Roberto @feabhas
                        Hi @feabhas
                        yeah, that sounds about right. Change that please. Ill edit the post accordingly Thanks
                          Colateral @Roberto
                          @Roberto Your example it is a good start but looping and blocking might not be a good approach.
                          We built another script that is using threads with blocking socket ... and run the script on a minimal Lora "star" network: one GW and 2 NODES. For each device you have to configure tx,rx and device id in cfg file . and upload the script and cfg file on it and run the script in Putty (not Pymakr). We didn't faced with this script clashing issues.. but we faced other issues.
                          You will see that after awhile on GW, the script is ending with a memory leak... but this is never happening on the nodes.
                          If you run the script from 3 Pymakr instances ... sometimes is working for hours and after that the GW is stop sending.
                          We conclude that is something wrong on the stack.
                          The issue might be related only to rx_iq configuration.
                          https://drive.google.com/drive/folders/0BzRE8IpnMMnLNHBseDJWblN4VGM?usp=sharing
                          • R Offline
                            Roberto @Colateral
                            Hi @Colateral
                            As i wrote in my last message, there is a new example of the nano-gateway with a non-blocking loop approach.
                            Regarding the memory issues we will look into this. I left the code on the other post running for 3 hours without any problems. I will leave it running today on a test bench for 24+ h to see if there are any problems and monitor the memory while it transmits. Will let you know the results.
                            The link to the new code is
                            https://forum.pycom.io/post/3242
                              Colateral @Roberto
                              @Roberto HI Roberto. Thanks. I ran the last script and is running fine. Regarding the memory leak, I believe is related with socket blocking approach. If we change the script and move to non blocking (as your script does) everything works fine.
                              • R Offline
                                Roberto @Colateral
                                @Colateral
                                Thanks for the quick response, i'll try a blocking approach to see if i can reproduce the error and check whats the root of it.
                                  assia
                                  @Colateral said in LoPy Nano-Gateway:
                                  Hi @Roberto i am bbegginer in LoRa and i don't understand the use of rx_iq and tx_iq.!
                                  thanks
                                  • B Offline
                                    borjam @assia
                                    @assia said in LoPy Nano-Gateway:
                                    It's easy. A LoRaWAN network is not a peer to peer network. There is a master (the gateway) that communicates with the nodes, but there is no node to node communication.
                                    Imagine that one of your nodes has the receiver active and another one transmits. The transmission is intended to be received by the gateway, of course (we said that there is no node-to-node communication) but the receiving node will get the packet anyway, if only to discard it.
                                    That reception and discarding has an energy cost. How do you avoid it? By having the nodes transmit in a mode that a node can't understand, only the gateway.
                                    Now, imagine this scenario: you make the nodes use tx_iq inversion (which is a sort of signal inversion) and the gateway use rx_iq inversion.
                                    In this case, a signal transmitted by a node will be inverted, and the gateway will successfully decode it. But other nodes, expecting a non inverted signal, won't detect the inverted signal. So you have just avoided the unintended packet reception problem.
                                    A C 2 Replies Last reply Reply Quote 1
                                      assia @borjam
                                      @borjam
                                      Thanks for the quick response, It's much clearer now.
                                        Colateral @borjam
                                        @borjam So how you can implement a mesh network using Lora? You put the GW in both tx and rx ?
                                          assia
                                          Hi @Roberto I tried to modify your code because I need to send a payload that contains the current time with a header containing mac address of the node and the length of the payload. Everything went well on the node side but rated nano gateway I have an Index Error: bytes index out of rang. it is because the adresse mac ? knowing that lora.mac() give : b'p\xb3\xd5I\x95kA\xf3' with length=8 but i don't understand what does mean the : b'p......' and how the length is 8 !!
                                          thanks
                                          node
                                          # LoRa node
                                          SRC_ADR_MAC=lora.mac()
                                          #compteur packets
                                          PACKETs_Cnt=5
                                          while(PACKETs_Cnt>0):
                                              # Package send containing a simple string
                                              msg=time.time()
                                              msg_len=len(str(msg))
                                              pkg = struct.pack('!%dsBi' % len(SRC_ADR_MAC), SRC_ADR_MAC, msg_len, msg)
                                              lora_sock.send(pkg)
                                              PACKETs_Cnt=PACKETs_Cnt-1
                                              time.sleep(5)
                                          nano GW
                                          # LoRa GW
                                          while (True):
                                              recv_pkg = lora_sock.recv(255)
                                              if (len(recv_pkg) > 2):
                                                  device_adr_mac, msg_len, msg = struct.unpack('!%dsBi' %8 ,   recv_pkg)
                                          # %8 because len(lora.mac())=8
                                                  print('Device: %s - Pkg:  %s' % (device_adr_mac, msg))
                                              time.sleep(5)
                                          • M Offline
                                            MJ
                                            Hi there, i am still new to lopy. I have try the example of the Lora.nanogateway code (https://docs.pycom.io/chapter/tutorials/lopy/lora-mac-nano-gateway.html) with only 1 lopy as gateway and 1 lopy as node. There is no response between both of them after i have coded it. What happen to this? Thank you.
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 3 / 4
