NBIoT Support, lack of
Very disappointed to find out, when digging into the commands, that NBIoT operation is not supported. That's why I bought the module. LTE CAT M1 not supported in my Geo.
When will NBIoT support be provided?
@borbonjuggler take also a look at this: https://forum.pycom.io/topic/3549/important-update-regarding-lte-modem-updates
Hi @borbonjuggler, first of all you have to update your sequans modem and you absolutely need support of band = 8 in your sequans modem. For connection to NB provided by TMA it is absolutely necessary! Last year pycom invited gpy-customers to initiate an RMA process for the boards, because at this time it was not possible to activate band 8 by users. i guess that currently shipped gpy-modules should support band 8 (?). Once you have band 8 available, you can follow the NB-IoT tutorial on https://docs.pycom.io/tutorials/lte/nb-iot.html. As far as i remember, last time i didn't even have to use the apn-parameter and band-parameter - simply lte.attach() worked fine.
Hello @kurt-renauer I am trying to set up my GPy with a T-Mobile Austria SIM without any success, I am quite new with this, so I after dig a bit in the forum post, I mash up something like this. However, I have not managed to connect to the network
lte.send_at_cmd('AT+CREG=1') print(".", end='') lte.send_at_cmd('AT+CGDCONT=1,"IP","m2m.nbiot.t-mobile.at"') print(".", end='') lte.send_at_cmd('AT+CGAUTH=1,1,"m2m","sim"') print(".", end='') lte.send_at_cmd('AT!="RRC::addscanfreq band=28 dl-earfcn=9410"') print(".", end='') lte.send_at_cmd('AT+CFUN=1')I was wondering if you can give me any advice for achiving connection.
Hi @combaindeft,
Send an email to bettina@pycom.io, she'll be able to give you more information on your question
How is the status of maybe supporting NB-IOT in Scandinavia? ... via Telia ? ...
They have announce global coverage in the entire Scandinavian region?
Even if you don't have support right now, we can assist, as we got FiPy modules and nano-sims from Telia and we got some good relationship with Telia and can recieve some help from their technicians :)
/Daniel.
@jmarcelino Can we have an update on NB-IOT? Thanks
@jmarcelino Do you have any idea about when you will support Norway/Telia? And when the NB-IOT api will be available to use? I'm writing a master thesis on power consumption in IOT and want to do a comparative analysis of Lora vs NB-IOT. I already use Lopy's for the Lora part, but I'm looking into using the GPy or the FiPy for the LTE-M/NB-IOT part. Any updates in regards to estimates for everything needed to be able to start testing (firmware, software apis etc) would be highly appreciated :)
@jmarcelino Count me in for testing! I’m in United States. I believe Verizon has CAT-M1 and NB-IoT coverage where I live. I am using hologram.
Let me know if you need anything else.
Just for your information.
NB IoT is being deployed in major cities in Spain by Vodafone, we have some Quectel units rolling
Cat M1 will be used and deployed in the upcoming Mobile World Congress in Barcelona by Telefonica Spain
@jmarcelino Can you also answer the same question for The Netherlands? I bought the board to testdrive both NB-IoT and LTE-M. T-Mobile was the first that has NB-IoT running so I would like to use the FiPy with their network. They also have a nice technical group & community that possible is willing to assist with the test of using the FiPy.
@ls
We hope to support Huawei-based NB-IoT networks such as Vodafone Spain by late March - this isn't under our control as that support comes from LTE chipset manufacturer. Thank you for your patience.I'm also not aware of any other live NB-IoT or Cat M1 network in Spain.
Hi jmarcelino, When should we expect a solution for LTE in Spain then? Please realize that Pycom never announced that Spain would not work for the moment when we placed the purchase order.
Is CAT M1 or NBIOT working in Spain with other operator (maybe Orange, Movistar, etc.)?
@ls
We are supporting Vodafone across Europe, however Vodafone Spain is a using Huawei which - as much as we'd like to - we won't be able to support with the first firmware releases.
In Spain we will test it with Vodafone too. Other NBIOT devices work perfectly and we expect FiPy to be the same. Is Vodafone Spain in your roadmap? Will it be ready in February too?
@jmarcelino
Hi, my country of interest is Austria and I already have a NB-IoT SIM from T-Mobile Austria. I am looking forward to support you with testing. Let me know if T-Mobile is on your roadmap.
Thx, Kurt
Best wishes - I know from experience that it can be difficult to achieve reliable carrier support. Lots of variables :)
@mhibbett
Thanks - and good news our initial implementation should be compatible with Vodafone Ireland.
@jmarcelino I'm in Dublin, Ireland. I have a Vodafone SIM. Any help I can provide with your tests, feel free to reach out.
Cheers,
Mike.
