    Lopy with pytrack, how connect/use GPS?
    gpslopypytrack
    76 Posts 5 Posters 35.8k Views 5 Watching
    • sebS Offline
      seb
      That error message means the library was not able to detect the Pytrack. Are you sure you have connected your module to your pytrack board properly, are all the pins pushed in fully? Have you updated the firmware on your Pytrack board to the latest available? (note: this is not the same as the firmware of the main pycom module)
      Z 1 Reply Last reply Reply Quote 0
      • Z Offline
        zceld @seb
        @seb
        Well, since you told me in the procedure to update it. Therefore I have the 'pytrack' and 'pycom' plate:
        I understand that the board is well connected because I connect with it by the usb from pytrack to Atom and it responds to all commands os. , for example pycom.heartbeat (False) and the LED goes off. I also upload a short video and show you the directory listings.
        video/gif:
        https://imgur.com/a/eQl9h
        Directory:
        Everything you need I'll show you to know or reach the solution.
        • sebS Offline
          seb
          Thanks for confirming all of that. To debug this further could you change the following two lines of code in pycoproc.py so we can see in more detail what error is occurring:
          108        except Exception:
          109            raise Exception('Board not detected')
          to
          108        except Exception as e:
          109            print(e)
          110            raise Exception('Board not detected')
          • Z Offline
            zceld
            @seb
            ok, I added the line of code you indicated and updated the file on the board:0_1516205098806_Captura de pantalla 2018-01-17 17.00.48.png
            I check that the lines of code are in the uploaded file:
            Bien, pues pruebo de nuevo a ejecutar el main.py:
            Result:
            • sebS Offline
              seb
              Thats odd, its showing that the firmware version is outdated but you showed me the screenshot of you updating it. Can you please run the following in the REPL after the error:
              py.read_fw_version()
              and post back what it returns?
              • Z Offline
                zceld @seb
                true !, according to the console and the screenshot I answered that it had been updated successfully. I will also do it again from this pc that is different. For trying, I lose nothing.
                • sebS Offline
                  seb
                  you typed that in wrong, its py not pycom
                  • Z Offline
                    zceld @seb
                    @seb yes! Sorry, as I gave an error I was trying and I sent you a test here you have the complete test.0_1516206577679_Captura de pantalla 2018-01-17 17.28.45.png
                    You will also have to apologize for taking a long time to answer the forum, it does not allow me to respond faster.:
                    • sebS Offline
                      seb
                      I upvoted some of your posts, the limit should now be much shorter.
                      ok sorry, can you try running this instead:
                      from pytrack import Pytrack
                      py = Pytrack()
                      • Z Offline
                        zceld @seb
                        @seb
                        Thank you very much for all the support, I have made the indicated and I keep saying the same.
                        • sebS Offline
                          seb
                          Ah, thats annoying, because the error happens when trying to create py and fails we cant then use it later. I am afraid you will have to edit the library some more:
                                      if self.read_fw_version() < 6:
                                          raise ValueError('Firmware out of date')
                          to
                                          raise ValueError('Firmware out of date (Version: {})'.format(self.read_fw_version()))
                          I will make some changes to the library on github once we solve this to make this easier in the future.
                          • Z Offline
                            zceld
                            @seb
                            I am also trying to update from this PC again as I mentioned and it is a Mac, but this command that indicates the guide does not accept it:
                            https://docs.pycom.io/chapter/pytrackpysense/installation/firmware.html
                            I update this part above to show you that I finally got back to update the board through the Mac:
                            <-------------- current topic: ------------------->
                            Well I have made the changes, updated the file in the pycom.
                            I have tried again the previous and even the main.py but it still fails. I will also try to update the pytrack with Mac.
                            @seb said in Lopy with pytrack, how connect/use GPS?:
                            • Z Offline
                              zceld @zceld
                              @zceld
                              okay! it seems that the update of the pytrack was not effective for windows despite the screenshot showed that yes, because now at least we can call the class Pytrack ().
                              The problem when running the main.py that in my case is called main3.py but that it is the same program as this one:
                              Well now the fault is as follows:
                              At least we have already advanced! ;-)
                              • Z Offline
                                zceld @zceld
                                @zceld
                                It seems that at least you have tried a couple of times, get the coordinates!
                                After I forget this, I would not know how to fix it:
                                Afterwards he does not let me try it anymore:
                                • Z Offline
                                  zceld
                                  @zceld
                                  Well finally it seems that with this code at least try to get the GPS coordinates.
                                  On the other hand now comes another problem and it seems that it runs out of memory. What do you think? the idea of operation is to collect the signal from the gps of a vehicle and send it to LoRa. I understand that if it is due to lack of memory, it will be necessary to program something to clean the cache or something that increases when using the program, not?
                                  CODE:
                                  from L76GNSS import L76GNSS
                                  py = Pytrack()
                                  l76 = L76GNSS(py, timeout=30)
                                  while (True):
                                  coord = l76.coordinates()
                                  print(coord)
                                  I am waiting for new news. Thank you very much for your patience
                                  • Z Offline
                                    zceld
                                    @zceld
                                    I am happy to inform you that with this code I have at least managed to obtain coordinates without failure:
                                    Code:
                                    import math
                                    import network
                                    import os
                                    import utime
                                    from machine import RTC
                                    from machine import SD
                                    from machine import Timer
                                    # setup as a station
                                    import gc
                                    time.sleep(2)
                                    gc.enable()
                                    # setup rtc
                                    rtc = machine.RTC()
                                    rtc.ntp_sync("pool.ntp.org")
                                    utime.sleep_ms(750)
                                    print('\nRTC Set from NTP to UTC:', rtc.now())
                                    utime.timezone(7200)
                                    print('Adjusted from UTC to EST timezone', utime.localtime(), '\n')
                                    py = Pytrack()
                                    chrono = Timer.Chrono()
                                    chrono.start()
                                    #sd = SD()
                                    #os.mount(sd, '/sd')
                                    #f = open('/sd/gps-record.txt', 'w')
                                    while (True):
                                    #f.write("{} - {}\n".format(coord, rtc.now()))
                                    print("{} - {} - {}".format(coord, rtc.now(), gc.mem_free()))
                                    Result:
                                    Thank you very much to all of you who have had to endure my clumsiness and have helped me especially: @seb and @livius, include @crumble ! :-)
                                    taking advantage of the post with the doubts and problems that I have had, I will shortly upload a guide in Spanish (since it is already in English) on the subject to facilitate other people.
                                    • O Offline
                                      olliec
                                      @zceld I appear to be having a similar issue that you were having, with a LoPy4 and PyTrack.
                                      My error however is "I2C bus error"..
                                      I've updated the PyTrack to 0.0.8 (tried via Windows 10 and Debian) and LoPy4 to 1.14.0.b1, ran "os.mkfs('/flash')" and re-uploaded the files from a ZIP download of the Git (https://github.com/pycom/pycom-libraries).
                                      This is what I get (I added the "print(e)" in pycoproc.py which is returning "I2C bus error"):
                                      @zceld - was there anything else you did other than update PyTrack via your Mac?!
                                      • Z Offline
                                        zceld @olliec
                                        @olliec said in Lopy with pytrack, how connect/use GPS?:
                                        hello, well, you'll see that the only thing I did was really update, I attached the screenshots of what I did. I honestly do not know why you can fail, surely you can get a hand those who really know. The teachers who have guided me.
                                        Screenshots:
                                        Greetings, I will be here attentive to your problem to know how it is solved. luck.
                                        O 1 Reply Last reply Reply Quote 0
                                        • O Offline
                                          olliec @zceld
                                          @zceld :( yeah I think my error is different.. I'll start a new thread. Thanks anyways!
                                          • Z Offline
                                            zceld @olliec
                                            @olliec good luck!
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 2 / 4
