    [Pysense] How can I connect a sensor to the external IO Header
    pysenseheaderspicinterruptpins
    25 Posts 10 Posters 11.0k Views 10 Watching
    • pierrot10P Offline
      pierrot10 @jclo13
      @jclo13 Hello,
      I am on a good way, but I postponed that project due to other emergency tasks. I planned to be back with Pycom in a couple of weeks. I will update you.
        pierrot10 @seb
        @seb Dear Seb,
        But would it possible or recommended to solder header on the side of the LoPy?
        alt text
        J S 2 Replies Last reply Reply Quote 0
          jmarcelino @pierrot10
          @pierrot10
          I’m afraid Seb has left Pycom but I’ll answer.
          Soldering a header to the side could work but not very mechanically stable. If it breaks it may take some of the pads.
          I would recommend a female long pin stacking header for your application
            DDA @pierrot10
            @pierrot10
            I see a problem with the schematics above, when reading multiple WM sensors the ground paths should be isolated:
            Sensors must be powered individually, and the ground must be isolated from sensor to sensor. Even if powered individually, an open ground path to another un-powered sensor can't be allowed. This is best accomplished using multiplexers to open and close the appropriate channels.
            For additional details please refer to :
            www.irrometer.com/200ss.html
              sslupsky @pierrot10
              Hi @pierrot10 The internal ADC has very poor performance. The non linearity is poor and it has a high noise floor. I think someone earlier suggested using an external ADC and I think that is very good advice.
              • 1
              • 2
              • 2 / 2
