LoPy DevEUI set to 0000000000000000
  • Hello,
    The first time I got the LoPy DevEUI (dev_eui = binascii.hexlify(network.LoRa().mac())), it was a normal DevEUI type (70b3d549XXXXXXXX). A day after, it was 00000000000000.
    What could have occured to erase the hardcoded DevEUI of the LoPy?
    Thanks,
    Guizmo
  • I have the same problem after upgrading to release='1.16.0.b1', version='v1.8.6-849-055728a on 2018-02-13'
    now I have to do a wlan init (and wlan deinit) to get the mac address
    firmware bug?
    tnx
    André
  • I am using following script to set arbitrary DevEUI:
    fo = open("/flash/sys/lpwan.mac", "wb")
    mac_write=binascii.unhexlify("b44b2bdfea11fdb9")
    fo.write(mac_write)
    fo.close()
    Then reboot the device.
    "b44b2bdfea11fdb9" is an example of arbitrary DevEUI
  • Could you please email me your wifi mac address to sebastian@pycom.io. You can get this by running:
    from network import WLAN
    import binascii
    print(binascii.hexlify(WLAN().mac()))
  • @seb
    I used the Firmware update tool (last version) before loading any code on the board
    I also flashed the board with the mkfs command
  • Have you performed any firmware updates, or tried to flash your own firmware?
