Gpy + Pysense - urequests AttributeError: 'module' object has no attribute 'get'
  • Hi
    I am trying to make an HTTP get request for testing but have getting this message:
    urequests.py library downloaded from https://github.com/micropython/micropython-lib/tree/master/urequests
    Please give me some help, i am started with Pycom...
    Network found!
    WLAN connection succeeded!
    RTC Set from NTP to UTC: (2018, 2, 28, 14, 23, 38, 97276, None)
    File "main.py", line 11, in <module>
    MicroPython v1.8.6-849-055728a on 2018-02-13; GPy with ESP32
     # boot.py
    from network import WLAN
    wlan = WLAN(mode=WLAN.STA)
    nets = wlan.scan()
    for net in nets:
        if net.ssid == 'REMOVED':
            print('Network found!')
            wlan.connect(net.ssid, auth=(net.sec, 'REMOVED.'), timeout=5000)
            while not wlan.isconnected():
    # main.py
    import urequests as requests
    import utime
    from machine import RTC
    rtc = machine.RTC()
    rtc.ntp_sync("pool.ntp.org")
    utime.sleep_ms(750)
    print('\nRTC Set from NTP to UTC:', rtc.now())
    r = requests.get('http://api.xively.com/')
    print(r)
    print(r.content)
    print(r.text)
    print(r.content)
    print(r.json())
    r.close()
  • @seb Everything work fine, after sync again!
    Thank you very much
  • @madeira199
    Ah there seems to have been an issue syncing the library because the output should be:
    >>> print(dir(requests))
    ['put', 'post', 'usocket', 'patch', 'request', '__file__', '__name__', 'delete', 'head', 'Response', 'get']
    >>> print(type(requests))
    <class 'module'>
    Can you please run the following to clear your device and sync again:
    import os
    os.mkfs('/flash')
    thank you very much for your help!
  • @madeira199
    In the REPL console can you please run the following:
  • @seb Yes i have the latest firmware, updated yesterday, Gpy, and Pysense
    i have patch line 53, and the problem remains
    1. Are you on the latest firmware?
    2. Are you sure you have correctly downloaded the urequest.py file from the link you provided? When I attempted to run this code I could not replicate your error. I did however have to patch line 53 to be:
        ai = usocket.getaddrinfo(host, port)
