    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 28.1k Views 6 Watching
      livius @Archana Kadam
      @archana-kadam
      1. what you get when you do
      nets = wlan.scan()
      print(nets)
      1. is there your net ssid? and is there info about WPA2?
      2. do you use static IP?
        this line is for static ip settings - but you must change it to follow your router settings
      wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
        Archana Kadam @livius
        @livius
        By using
        nets = wlan.scan()
        print(nets)
        we are getting details of connected WiFI.
        Yes we have our net ssid and is configured to WPA2. Yes we were using this wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
        to configuration. How we can know that our WIFI is connected or disconnected
          @archana-kadam
          you have wlan.isconnected() for that look here:
          https://docs.pycom.io/chapter/tutorials/all/wlan.html#connecting-to-a-router
          and are you sure that your router have same ip settings? 192.168.0.1?
            @livius
            from network import WLAN
            wlan = WLAN(mode=WLAN.STA)
            nets = wlan.scan()
            for net in nets:
                if net.ssid == 'mywifi':
                    print('Network found!')
                    wlan.connect(net.ssid, auth=(net.sec, 'mywifikey'), timeout=5000)
                    while not wlan.isconnected():
                    break
            Using above code we are getting the details of connected wifi. And we have different ip address.0_1520939453939_screnshot.PNG Here is the screenshot of our output please go through the image and update.
            Thank You
              @archana-kadam
              than you are connected to wifi - what more do you need?
              A 2 Replies Last reply Reply Quote 0
                @livius
                How we can know that is connected to Wifi?
                How we can connect to both station as well as access point?
                  @livius
                  Please explain the procedure of connecting fipy to server and how to send data of fipy to server
                    @archana-kadam said in Not getting Sensor Readings in Pysense with FiPy Module:
                    wlan.isconnected()
                    but to be really sure - only sending by socket tell this for sure
                    change mode from WLAN.STA in WLAN.STA_AP
                    simply create socket and send data throught it
                    e.g. from memory not tested but something like this should work
                    s = socket.socket()
                    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
                    s.connect(socket.getaddrinfo('your server ip', your_server_port)[0][-1])
                    s.send(your_data)
                      @livius
                      Can we send data through pybytes ?
                      Is a pybytes a server or its just a middleware to send data?
                        @livius
                        From this above code we are getting an error called OSERORR :-01
                        s = socket.socket()
                        s.connect(socket.getaddrinfo('192.168.0.109', 80)[0][-1])
                        your_data = "Hello"
                        s.send("your_data")
                          @archana-kadam
                          At which line of code?
                            @livius
                            Line number 6 and 7
                              Line number 6 and 7
                              I do not have your source code ;-)
                              what this lines contain? and why on 6 and 7 - error should be raised only once
                                @livius
                                host = '127.0.0.1'
                                port = 80 # The same port as used by the server
                                s.connect((host, port))
                                s.send('Hello, world')
                                data = s.recv(1024)
                                s.close()
                                print('Received', repr(data))
                                Here is code to connect to server,but we are enable to connect
                                  @livius
                                  configure the WLAN subsystem in station mode (the default is AP)
                                  go for fixed IP settings (IP, Subnet, Gateway, DNS)
                                  wlan.scan() # scan for available networks
                                  wlan.connect(ssid='mynetwork', auth=(WLAN.WPA2, 'my_network_key'))
                                  pass
                                  print(wlan.ifconfig())
                                  I tried with code also, but its continuously running but there no output.
                                    @archana-kadam
                                    I should start with this question, what is your firmware version?
                                    import os
                                    os.uname()
                                      Archana Kadam @Archana Kadam
                                      @livius
                                      Is Pybytes a server. Can we send data and store in pybytes
                                        @livius
                                        We have latest version of firmware installed 1.17.b
                                          @archana-kadam
                                          You can send data to whatever you like, but for pybytes you need account.
                                          Did you successfully connected to the wifi network?
                                            @livius
                                            We are running the below code on the FiPy to send data to the server. and we are using FiPy in its default mode i,e Access Point Mode.
                                            s = socket.socket()
                                            your_data = "Hello"
                                            s.send("your_data")
                                            Can you send us the one complete example code which sends data from fipy to server. Where a local computer in the same network can be used as server.
                                            Thank You
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 2 / 4
