Lopy Nano-Gateway
  • Hi, currently i am using the code from https://docs.pycom.io/chapter/tutorials/lopy/lora-mac-nano-gateway.html and i have adding in some code to suit my application which is measure the time of receiving the ACK from the gateway by adding the Timer and send back the time value back to gateway. Unfortunately, i face the problems. Sorry for the unprofessional coding way since i am still new in programming.
    Gateway code :
    For Node 1:
    • the coding for node 1 and node 2 is the same instead of the Device ID.
    Any help from others would appreciate, thank you.
  • @mj I do not know what you intention was, but may something like this, which just changes the message content and initializes total for the first run.
    import os
    import struct
    import network
    from network import LoRa
    from machine import Timer
    # A basic package header, B: 1 byte for the deviceId, B: 1 byte for the pkg size
    _LORA_PKG_FORMAT = "BB%ds"
    _LORA_PKG_ACK_FORMAT = "BBB"
    DEVICE_ID = 0x01
    # Open a Lora Socket, use tx_iq to avoid listening to our own messages
    # Asia = LoRa.AS923
    # Australia = LoRa.AU915
    # Europe = LoRa.EU868
    # United States = LoRa.US915
    chrono = Timer.Chrono()
    lora = LoRa(mode=LoRa.LORA, frequency = 915000000)
    lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
    lora_sock.setblocking(False)
    total = 0
    while(True):
        # Package send containing a simple string
        msg = "Device 1 Here, Time difference %d total" % total
        pkg = struct.pack(_LORA_PKG_FORMAT % len(msg), DEVICE_ID, len(msg), msg)
        lora_sock.send(pkg)
        # Wait for the response from the gateway. NOTE: For this demo the device does an infinite loop for while waiting the response. Introduce a max_time_waiting for you application
        waiting_ack = True
        while(waiting_ack):
            recv_ack = lora_sock.recv(256)
            chrono.start()
            if (len(recv_ack) > 0):
                device_id, pkg_len, ack = struct.unpack(_LORA_PKG_ACK_FORMAT, recv_ack)
                if (device_id == DEVICE_ID):
                    if (ack == 200):
                        chrono.stop()
                        total = chrono.read_us()
                        waiting_ack = False
                        # If the uart = machine.UART(0, 115200) and os.dupterm(uart) are set in the boot.py this print should appear in the serial port
                        print("ACK")
                        waiting_ack = False
                        print("Message Failed")
        time.sleep(5)
  • Hi, @robert-hh sorry for the inconvenient caused. Here is the code:
    Gateway :
    import struct
    # A basic package header, B: 1 byte for the deviceId, B: 1 byte for the pkg size, %ds: Formatted string for string`
    _LORA_PKG_FORMAT = "!BB%dsf"
    # A basic ack package, B: 1 byte for the deviceId, B: 1 byte for the pkg size, B: 1 byte for the Ok (200) or error messages
    # Open a LoRa Socket, use rx_iq to avoid listening to our own messages`
    `# Please pick the region that matches where you are using the device:
    # Asia = LoRa.AS923
    while (True):
        recv_pkg = lora_sock.recv(512)
        if (len(recv_pkg) > 2):
            recv_pkg_len = recv_pkg[2]
            device_id, pkg_len, msg = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
            print('Device: %d - Pkg:  %s' % (device_id, msg))
            ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, 1, 200)
            lora_sock.send(ack_pkg)
    Node :
    import os
    import struct
    import network
    _LORA_PKG_FORMAT = "BB%dsf"
    DEVICE_ID = 0x01
    # Asia = LoRa.AS923
    while(True):
        msg1 = "Device 1 Here"
        msg2 = "Time difference %f total"
        msg = "format_string % (msg1,msg2)"
        lora_sock.send(pkg)
        waiting_ack = True
        while(waiting_ack):
            chrono.start()
                    if (ack == 200):
                        chrono.stop()
                        waiting_ack = False
                        print("ACK")
                        waiting_ack = False
        time.sleep(5)
    The problem that i face is the : "buffer too small " , "cannot convert str to int", "3 more values to unpack" . I have no idea on how it works since i am still new in python programming, any help would appreciate. Thank you.
  • @mj The code is hard to see the way you post it. if you enclose it in lines with three backticks each (```) you can paste you code directly in the message.
