    nvram lopy Errno 100
    lopypysenseerror
    12 Posts 4 Posters 2.2k Views 4 Watching
    • H Offline
      han
      Re: lora.nvram example needed
      Hello Pioneers,
      I am using the Lopy to send data from the pysense and a external sensor.
      When I work without the lora.nvram_restore() & save() function, it works fine but the module does not connect after coming out of deepsleep.
      When i use the nvram function there pops up a error message: OSError:
      File "main.py", line 74, in <module>
      [Errno 100] ENETDOWN
      Line 74 is "s.send(enc)"
      Does somebody know how to resolve this?
      I am using a LoPy and a Pysense with the newest firmware version.
      Atom 1.25.0 and Pymakr plugin 1.2.11.
      On KPN LoRa network
        jcaron @han
        @han Can you provide the relevant parts of your code? My guess is that you don't have the nvram_save and nvram_restore calls in the right places, but it's hard to tell without code...
        • H Offline
          han
          Hello @jcaron
          This is my code.
          # LoRaWAN (ABP)
          from network import LoRa
          from mqtt import MQTTClient
          import binascii
          import struct
          from deepsleep import DeepSleep
          import ujson
          import gc
          from pysense import Pysense
          from SI7006A20 import SI7006A20
          from LTR329ALS01 import LTR329ALS01
          from MPL3115A2 import MPL3115A2,ALTITUDE,PRESSURE
          py = Pysense()
          mp = MPL3115A2(py,mode=ALTITUDE)
          mpp = MPL3115A2(py,mode=PRESSURE) # Returns height in meters. Mode may also be set to PRESSURE, returning a value in Pascals
          si = SI7006A20(py)
          lt = LTR329ALS01(py)
          ds = DeepSleep()
          gc.enable()
          # Initialize LoRa in LORAWAN mode.
          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
          dev_addr = struct.unpack(">l", binascii.unhexlify('xxxxxx'.replace(' ','')))[0]
          nwk_swkey = binascii.unhexlify('xxxxxxx'.replace(' ',''))
          app_swkey = binascii.unhexlify('xxxxxxx'.replace(' ',''))
          # join a network using ABP (Activation By Personalization)
          print('Joined LoRa network')
          # wait until the module has joined the network
          while not lora.has_joined():
              time.sleep(2.5)
              print('Not joined yet...')
          # remove all the non-default channels
          for i in range(3, 16):
              lora.remove_channel(i)
          # create a LoRa socket
          # set the LoRaWAN data rate
          # make the socket blocking
          # (waits for the data to be sent and for the 2 receive windows to expire)
          s.setblocking(True)
          time.sleep(5)
          for i in range (200):
              mqData = {}
              gc.collect()
              mqData ["data"] = {}
              mqData ["data"]["Temperature"] = mp.temperature()
              mqData ["data"]["Pressure"] = (mpp.pressure()/100)
              mqData ["data"]["Relative Humidity"] = si.humidity()
              mqData ["data"]["Battery voltage"] = py.read_battery_voltage()
              enc = ujson.dumps(mqData)
              gc.collect()
              s.send(enc)
              print('STA node sending packet ...')
              time.sleep(5)
              nvram_save()
              print("ready to DeepSleep")
              print("Going to DeepSleep")
              py.setup_sleep(15*60)
              py.go_to_sleep()
          code
            robert-hh @han
            @han if you enclose your code in line with three backticks (```), the structure is maintained.
            • H Offline
              han @robert-hh
              @robert-hh Thanks for the tip. I will do it the next time when I have to upload a piece of code.
                jcaron @han
                @han not sure about ABP but for OTAA you definitely don’t join every time. You should just do nvram_restore() just after you create the lora object, and only join if has.joined() returns false.
                robert-hhR H 2 Replies Last reply Reply Quote 0
                  robert-hh @jcaron
                  @jcaron As far as I could see it, there is no actual communication done for ABP join. Just the device ID and the respective keys are set in the MAC layer.
                  Either way, nvram_save() and nvram_restore() should be used to ensure the monotonic increase of the packet counters.
                  • H Offline
                    han @jcaron
                    @jcaron
                    What do I have to do to make it work?
                    If I deleted the deepsleep part it work fine, but with the deepsleep the LoPy will not join again.
                      jcaron @han
                      @han As I said, move the lora.nvram_restore() just after creating of the loraobject, then test if lora.has_joined() and only do the join and probably the channel stuff if it has not joined yet.
                      H 1 Reply Last reply Reply Quote 1
                      • H Offline
                        han @jcaron
                        @jcaron did you find anything strange in my code?
                        • H Offline
                          han @jcaron
                          @jcaron
                          as I understood your tips.
                          Then should it be something like this. Right?
                          # LoRaWAN (ABP)
                          import binascii
                          import struct
                          import ujson
                          import gc
                          py = Pysense()
                          si = SI7006A20(py)
                          ds = DeepSleep()
                          gc.enable()
                          loraSaved = pycom.nvs_get('loraSaved')
                          if not loraSaved:
                              dev_addr = struct.unpack(">l", binascii.unhexlify('14 20 36 XX'.replace(' ','')))[0]
                              nwk_swkey = binascii.unhexlify('d0 ad 96 bb 95 0c b1 72 6a a4 3f 85 2f 4a XX XX'.replace(' ',''))
                              app_swkey = binascii.unhexlify('d5 ac 3b 1c 70 6c f8 2a 46 f2 2f eb 57 12 XX XX'.replace(' ',''))
                              print('Joining the LoRa network')
                                  time.sleep(2.5)
                                  machine.idle()
                              s.setblocking(False)
                              time.sleep(5)
                              s.send('LoRa Saved')
                              print("LoRa saved")
                              time.sleep(5)
                              lora.nvram_save()
                              pycom.nvs_set('loraSaved', 1)
                              time.sleep(5)
                              mqData = {}
                              gc.collect()
                              mqData ["m"] = {}
                              mqData ["m"]["T"] = mp.temperature()
                              mqData ["m"]["P"] = (mpp.pressure()/100)
                              mqData ["m"]["H"] = si.humidity()
                              mqData ["m"]["B"] = py.read_battery_voltage()
                              gc.collect()
                              s.send(enc)
                              pycom.nvs_set('loraSaved', 0) # reset for next test
                              print(enc)
                              print('LoRa data saved')
                              time.sleep(5)
                              ds.enable_pullups('P17')  # can also do ds.enable_pullups(['P17', 'P18'])
                              ds.enable_wake_on_fall('P17') # can also do ds.enable_wake_on_fall(['P17', 'P18'])
                              ds.go_to_sleep(30*60)  # go to sleep for 15 minutes
                          # get any data received...
                          data = s.recv(64)
                          print(data)
                          I still have the errno 100 error code. This time on rule 89.
                          • F Offline
                            ferfersan6
                            Hey! Did you solve it? I am having the same problem... Can't fix it. Thanks!
