    Error when uploading to LoPy4
    sigfoxlopybug
    3 Posts 2 Posters 878 Views 2 Watching
      Luxior
      It's been a few week that i can't upload anything anymore on my 2 LoPy4, i use expansion board 3.0, can't deal with the update for the expansion board(i'm on windows) but i updated the LoPy4 to the last firmware, and it solved nothing. I can run progs and it works well, but when i try to upload some, although it's saying "upload done", nothing happen.
      Could you help me a little bit ?
      Here is the upload msg and the error
      text alternatif
      i work on Visual Studio Code, with the plugin PyMakr
      Thanks in advance.
        jmarcelino @Luxior
        @luxior
        Do you have a project open in VSCode?
        Can you describe your project structure or perhaps post a screenshot of VSCode with your code open?
        It looks like the files are on the board already but if not called from main.py they don't get run.
          Luxior
          The file is called main.py, and it always was, so i don't think it can be it. I have a project created, and all the file are inside, i can access it through windows explorer as well, for the code, i can explain it, and post a screen about it if you want.
          I use the internal RTC (even if i can't update the time, i can initialise it and do something when X date is reached, even if there is no save if the system is not alimented anymore, that's enough for me) i also use an analogic pin for taking a battery pourcentage, and i send a message when a pin receive something.
          If you really want all the code here it is
          from network import Sigfox
          from machine import Pin
          from machine import RTC
          class ComSigFox:
              msg = ""
              localisation = ""
              socket = ""
              Etat = ""
              tailleManquante = 0
              Compteur = 0
              def __init__(self):
                  # Initialise SigFox en Europe (RCZ1)
                  localisation = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
              def sendMsg(self, paramMsg):
                  pycom.rgbled(0x007f00) # vert
                  # Créer un socket SigFox
                  # Bloque le socket
                  s.setblocking(True)
                  # Configure le socket en Uplink seulement (False / True)
                  s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
                  msg = paramMsg
                  msg += " %"
                  if((len(msg) ) < 5 ):      # Si le message fait en dessous de 5 caractères
                      tailleManquante = 5 - (len(msg))
                      for Compteur in range(tailleManquante):
                          msg = msg + " "
                          # On rajoute des espaces autant de fois
                          # Que nécessaire pour avoir 5 caractères
                  Etat = "Close"
                  if(Etat == "Open"):
                      Etat = "Open "
                  msg = msg + Etat
                  s.send(msg)
                  return True
          class Batterie:
              Voltage = 0
              Charge = 0
              def __init__(self):
                  pass
              def getBattery(self):
                  adc = machine.ADC(bits = 10)             # create an ADC object
                  apin = adc.channel(pin='P20', attn = machine.ADC.ATTN_11DB)   # create an analog pin on P20
                  i = 0
                  MoyenneVolt = 0
                  for i in range(1,50):
                      time.sleep(0.1)
                      val = apin() - 698
                      Mesure = (val / 1024) * 5
                      MoyenneVolt += Mesure
                  Voltage = MoyenneVolt / 49
                  print(Voltage)
                  # Condition tension avec équation 0 - 10% de charge
                  if(Voltage >= 1.32496 and Voltage <= 1.41429):
                      Charge = (429.71806 * pow(Voltage,2)) - (1065.15152 * Voltage) + 656.90476
                 # Condition tension avec équation 10 - 30% de charge
                  if(Voltage > 1.41429 and Voltage <= 1.45895):
                      Charge = (404108.59608 * pow(Voltage,3)) - (1741647.28089 * pow(Voltage,2)) + (2502325.58922 * Voltage) - 1198510
                  # Condition tension avec équation 30 - 60% de charge
                  if(Voltage > 1.45895 and Voltage <= 1.52594):
                      Charge = (540257.28470 * pow(Voltage,4)) - (3000615.37231 * pow(Voltage,3)) + (6220087.42278 * pow(Voltage,2)) - (5699263.94063 * Voltage) + 1945763.58460
                  # Condition tension avec équation 60  - 100% de charge
                  if(Voltage > 1.52594 and Voltage <= 1.58921):
                      Charge = (348000.83082 * pow(Voltage,3)) - (1629386.97406 * pow(Voltage,2)) + (2543268.59982 * Voltage) - 1323295.17637
                  Charge = int(round(Charge,0))
                  print("")
                  print(Charge)
                  print("")
                  # La fonction int() n'arrondit pas, elle ne fait que tronquer, ainsi, il faut faire un int de l'arrondi qui seras par exemple
                  # 49.0, le résultat seras donc le nombre 49.
                  return Charge
          class HorlogeRTC:
              rtc = 0
              Date = 0
              stringHeureDate = ""
              stringMinutesDate = ""
              stringSecondesDate = ""
              intHeureDate = 0
              intMinuteDate = 0
              intSecondesDate = 0
              HeureSouhaite = 0
              MinuteSouhaite = 0
              SecondeSouhaite = 0
              HeureFinal = 0
              MinuteFinal = 0
              SecondeFinal = 0
              TempsTotalAttente = 0
              def __init__(self):
                  rtc = RTC()
                  rtc.init((2018, 5 , 16 , 17, 19, 50, 0 ))
                  # rtc.init(Année , mois , jours , heures , minutes, secondes, millisecondes)
              def getTime(self):
                  Date = RTC().now()
                  return Date
              def CalcTime(self,Date):
                  Jour = False
                  stringHeureDate = Date[3]
                  stringMinutesDate = Date[4]
                  stringSecondesDate = Date[5]
                  s_intHeureDate = int(stringHeureDate) * 3600
                  s_intMinutesDate = int(stringMinutesDate) * 60
                  s_intSecondesDate = int(stringSecondesDate)
                  s_TempsTotalActuel = s_intHeureDate + s_intMinutesDate + s_intSecondesDate
                  HeureSouhaite = 17 * 3600
                  MinuteSouhaite = 20 * 60
                  SecondeSouhaite = 10
                  s_TempsTotalSouhaite = HeureSouhaite + MinuteSouhaite + SecondeSouhaite
                  # TempsTotalAttente en seconde
                  if(s_TempsTotalSouhaite < s_TempsTotalActuel):
                      TempsTotalAttente = (s_TempsTotalSouhaite - s_TempsTotalActuel) * -1
                      TempsTotalAttente = s_TempsTotalSouhaite - s_TempsTotalActuel
                  if(Jour == False):
                      Jour == True
                      return TempsTotalAttente
                  elif(Jour == True):
                      return 86400 + TempsTotalAttente
          def TempoVerifMesure(TempsRestantHorlogeParam):
              Max = 0
              Diviseur = 0
              TempsAttenteBoucle = str(TempsRestantHorlogeParam)
              print(TempsAttenteBoucle)
              if(len(str(TempsAttenteBoucle)) == 5):
                  Diviseur = 10000
                  TempsAttenteBoucle = int(TempsRestantHorlogeParam) / Diviseur
              if(len(str(TempsAttenteBoucle)) == 4):
                  Diviseur = 1000
              if(len(str(TempsAttenteBoucle)) == 3):
                  Diviseur = 100
              if(len(str(TempsAttenteBoucle)) == 2):
                  Diviseur = 10
              #Pin de l'ILS
              #ILS = Pin('P23',mode=Pin.IN,pull=Pin.PULL_UP)
              Max = Diviseur
              pycom.rgbled(0x7f0000) # red
              for i in range(0,Max,1):
                  time.sleep(TempsAttenteBoucle)
                  print("Tempo... {0}".format(Max))
                  #if(ILS() == True):
                  #    return True
              return True
          if __name__=="__main__":
              Horloge = HorlogeRTC() # On initialise la classe HorlogeRTC
              Battery = Batterie() # On initialise la classe Batterie
              SigFox = ComSigFox() # On initialise la classe ComSigFox
              while(True):  #Le programme tourne en permanance dans cette boucle
                  envoiSigFox = False
                  while(envoiSigFox == False): # Tant que le message SigFox n'est pas envoyé on boucle ici
                      Date = Horloge.getTime() # On récupère la date
                      TempsRestantHorloge = Horloge.CalcTime(Date) # On calcule le temps restants avant la date souhaite en secondes
                      intCharge = Battery.getBattery()
                      if(TempoVerifMesure(TempsRestantHorloge) == False): # Condition pour que le message SigFox s'envoie (Temporisation de TempsRestantHorloge + vérif ILS)
                          pycom.rgbled(0x7f7f00) # jaune
                          SigFox.sendMsg(str(intCharge))
                          envoiSigFox = True
