    Pymakr (VS Code) on Ubuntu 16.04
    ubuntuvscodepymakrissue
    1 Posts 1 Posters 591 Views 1 Watching
    • R Offline
      rimix2
      Hello all,
      I have an issue running Pymakr on VS Code on Ubuntu 16.04.
      I already installed Node.js, and plugin installation in VS code is not leading to any alarm. Anyway, I cannot see appearing the command bar with "Run" "Sync" and "Commands".
      I had no issue with another installation (on W10).
      You know what should I check further?
      Thanks!!!
      edit: I'm using 32bit versions
      edit2: I'm using 0.1.7 Pymakr and latest VSC version. I also tried to rollback VSC to July 17 version (1.15) but still no success
