    Wipy 3 irregularly crashes after deepsleep
    wipydeepsleepcrash
    3 Posts 2 Posters 754 Views 3 Watching
    • M Offline
      MoeweX
      I have been evaluating the deepsleep capabilities of my Wipy 3 quite intensively during the last days. I noticed that it always crashes after a random amount of deepsleep cycles upon which a hard reset is required.
      When it crashed, it has not connected to my WIFI (as specified in boot.py) and also did not setup its own WIFI, so I cannot access the REPL. However, it consumes power as it is warm. I am not sure whether the board crashes while going to deepsleep or while waking up from it.
      Am I doing something wrong or is this a firmware/hardware issue? Find below a boot.py and main.py that I can use to reproduce the problem, it usually occurs during the first hour.
      # boot.py -- run on boot-up
      def connectToWlan():
          from network import WLAN
          wlan = WLAN(mode=WLAN.STA)
          nets = wlan.scan()
          for net in nets:
              if net.ssid == '<SSID>':
                  print('Network found!')
                  wlan.connect(net.ssid, auth=(net.sec, '<AUTH>'), timeout=5000)
                  while not wlan.isconnected():
                      pycom.rgbled(0x7f0000) # red
                  wlan.ifconfig(config=('192.168.0.14', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                  print(wlan.ifconfig())
                  break
      # Code to be run on boot-up
      connectToWlan()
      time.sleep(1) # wait shortly
      # main.py -- runs after boot.py
      # Constants
      DEEPSLEEP_TIME = 2 # seconds
      print("Going to deepsleep in 10 seconds")
      for i in range(10):
          pycom.rgbled(0) # off
          time.sleep(0.5)
          pycom.rgbled(0xffa500) # orange
          time.sleep(0.5)
      print("Going to deepsleep")
      time.sleep(1) # better wait a little
      machine.deepsleep(DEEPSLEEP_TIME * 1000)  # must be milliseconds
      Personally, I think the Wipy crashes after the wake up and before boot.py is run, but I am not sure how to proof that without staring at the Wipy for an hour.
      T 1 Reply Last reply Reply Quote 1
        Tankfull @MoeweX
        @moewex I have been having the same issue. My deep sleep time is 60 minutes. The WiPy will function fine for 1 - 2 weeks, then it hits this stall out mode where it does not connect to wifi and heats up. Not sure where the issue is on this one.
        • M Offline
          MoeweX
          As of last week, I cannot reproduce the error anymore... . If I encounter the issue again, I will write here again.
