    CAT M1
    cat m1lte fipy simsimfipy
    2 Posts 1 Posters 558 Views 2 Watching
    • B Offline
      Burgeh
      Greetings,
      I am having issues attaching to the services. My SIM and IMEI are both registered. My code is below, any advice? I have both antennas attached and the SIM card inserted.
      It seemed to work once, it got to for sure the first green RGB blink, but hasn't since
      import ssl
      from network import LTE
      pycom.rgbled(0x7f0000) # red
      time.sleep(2)
      lte = LTE()         # instantiate the LTE object
      lte.attach()        # attach the cellular modem to a base station
      while not lte.isattached():
          time.sleep(0.25)
          print("Not Attached")
      lte.connect()       # start a data session and obtain an IP address
      while not lte.isconnected():
          time.sleep(0.25)
          print("not Connect")
      s = socket.socket()
      s = ssl.wrap_socket(s)
      s.connect(socket.getaddrinfo('www.google.com', 443)[0][-1])
      pycom.rgbled(0xff00)           # turn on the RGB LED in green colour
      time.sleep(2)
      s.send(b"GET / HTTP/1.0\r\n\r\n")
      print(s.recv(4096))
      pycom.rgbled(0x0000FF)           # turn on the RGB LED in green colour
      time.sleep(2)
      s.close()
      lte.disconnect()
      lte.dettach()
      • B Offline
        Burgeh @Burgeh
        Update: Some more information...
        I am in the USA, and registered the SIM card on a verizon network that mentioned it was compatible with the FiPY IMEI. Below is a screenshot of some commands. Firmware is 33080, this is old...could this be the issue?, but it seems Pycom is releasing a new modem update fix soon?
        Do I need to set the APN manually, or is there something I am missing?
        I have a CATM1 modem with the same kind of SIM card and it gets signal just fine here.
