    Wipy 3.0 consomme 6mA en DeepSleep
    wipy3.0batteryconsumptiondeep sleep
    4 Posts 3 Posters 834 Views 3 Watching
      GDA45-78
      Bonjour à tous,
      Rien qu'avec le code suivant, le Wipy 3.0 me consomme encore 6mA. Je suis loin des 120uA vue dans le forum ou de 19.6uA du datasheet.
      machine.deepsleep(10000)
      Une explication ?
        robert-hh @GDA45-78
        @gda45-78 How do you supply the device? By USB & expansion board: then the USB driver adds in.
        Do you have an other circuits connected, that consume power?
          GDA45-78
          I using only the lipo battery on VIN and GND pins on the breadboard.
          It's a simple circuit.
          So, I tested with an other WiPy 3.0 and the current in deepsleep's mode is correct....
          Thank
            Prx @GDA45-78
            @gda45-78 Hi, don't you have loaded a back WLAN process on the board that consume too much ? (see your post 3 months ago in your profile).
            regards.
