    Troubleshooting lte connections
    gpyltenb-iot
    4 Posts 3 Posters 814 Views 3 Watching
      shedaim
      I'm trying to connect to a private network using NB-IOT, but when I try to lte.connect() I always get a False.
      How can I check whether there is a problem with the SIM or I'm not even "seeing" the network.
      Should I be able to check for existing networks in the vicinity?
      Thanks,
      Shedaim
      A robert-hhR 2 Replies Last reply Reply Quote 0
        arneme @shedaim
        @shedaim Private network? The FiPy and GPy will only search for LTE NB-IoT and Cat M1 network in licensed bands. What do you mean with private? Licensed band requires an operator.
          shedaim @arneme
          @arneme We have a lab environment with a band 28 CAT-M1 and NB-IOT.
            robert-hh @shedaim
            @shedaim There is a problem in the lte.attach() API concerning parsing the response from the network. @xykon adresses this in a trial firmware build at [LINK NO LONGER AVAILABLE]
            Please download and install that (install from file). It may fix you problem.
            See also this thread around https://forum.pycom.io/topic/3549/important-update-regarding-lte-modem-updates/83
