    Trying to connect to LTE-M1
    lte-mkpnnot attaching
    17 Posts 8 Posters 3.8k Views 9 Watching
      ChielvDiepen
      I am trying to connect to the local KPN network. I found two networks in my area on band 20. KPN and Vodafone. I have a KPN-sim, so i tried to set the code to KPN with AT+COPS:2 etc. But when i try lte.isattach() it constantly give False. I tried to force register to a network with 'AT+COPS=1,2,"20408"' but this gives an error. Also the forced network disappears from the found networks in the erea. As far as i know KPN network is supported, it is also listed in 'AT+COPN'. The output can be find in the comments. I have tried waiting for 5-10 min with a while loop after the attach, but still no attaching happening.
      Who could help me out, to connect?
      from network import LTE
      lte = LTE()
      def send_at_cmd_pretty(cmd):
          response = lte.send_at_cmd(cmd).split('\r\n')
          for line in response:
              print(line)
      print("LTE-M1 procedure")
      #print("NB-IoT procedure")
      #send_at_cmd_pretty('ATZ') # Reset to default config
      #send_at_cmd_pretty('AT&F') # Reset to factory config
      #time.sleep(5)
      print("Resetting to factory config...", end='')
      send_at_cmd_pretty('AT^RESET') # Hard reset
      time.sleep(5)
      print("FSM status 1 ", end='')
      send_at_cmd_pretty('AT!="fsm"') # OK
      time.sleep(5)
      print('Status 1:')
      send_at_cmd_pretty('AT!="showphy"') # OK
      time.sleep(5)
      print("RF off mode / Low power... ", end='')
      send_at_cmd_pretty('AT+CFUN=0') # OK
      time.sleep(5)
      print("Clear scan configuration...", end='')
      send_at_cmd_pretty('AT!="clearscanconfig"') # OK
      time.sleep(5)
      print("Add band 20 to scan...", end='')
      send_at_cmd_pretty('AT!="addscanband band=20"') # OK
      time.sleep(5)
      print("Disable log 1....", end='')
      send_at_cmd_pretty('AT!="disablelog 1"') # OK
      time.sleep(5)
      print("Config of the LTE APN...", end='')
      send_at_cmd_pretty('AT+CGDCONT=1,"IP","item.internet.m2m"') # OK
      #send_at_cmd_pretty('AT+CGDCONT=1,"IP","Item.webtrail.m2m"')
      #send_at_cmd_pretty('AT+CGDCONT=1,"IP","Internet.m2m"')
      #send_at_cmd_pretty('AT+CGDCONT=1,"IP","M2MC.WEBTRAIL"')
      time.sleep(5)
      #print("Instellen van NB-IoT APN...", end='')
      #send_at_cmd_pretty('AT+CGDCONT=1,"IP","c.dpiot.t-mobile.nl"')
      #time.sleep(5)
      print("Add scanfreq band en dl-earfcn...", end='')
      send_at_cmd_pretty('AT!="RRC::addscanfreq band=20 dl-earfcn=6300"') # scan band 20/6240 of band 8/3650 of band 28/9410
      time.sleep(5)
      print("Turn module to full functionality...", end='')
      send_at_cmd_pretty('AT+CFUN=1') # OK
      print("wait 30 sec")
      time.sleep(5)
      print("wait 25 sec")
      time.sleep(5)
      print("wait 20 sec")
      time.sleep(5)
      print("wait 15 sec")
      time.sleep(5)
      print("wait 10 sec")
      time.sleep(5)
      print("wait  5 sec")
      time.sleep(5)
      print("FSM status 2 ", end='')
      time.sleep(5)
      print("Show list with networks...", end='')
      send_at_cmd_pretty('AT+COPS=?') # +COPS: (2,"NL KPN","NL KPN","20408",7)(1,"vodafone NL","voda NL","20404",7),,(0,1,2,3,4),(0,1,2)
      time.sleep(5)
      time.sleep(5)
      time.sleep(5)
      time.sleep(5)
      time.sleep(5)
      print("wait  5 sec")
      time.sleep(5)
      print("Current network...", end='')
      send_at_cmd_pretty('AT+COPS?') #  +COPS: 1
      time.sleep(5)
      print("Config to network 2: KPN", end='') # i want +COPS: 2 KPN
      send_at_cmd_pretty('AT+COPS=2')
      time.sleep(5)
      send_at_cmd_pretty('AT+COPS?') #  +COPS: 2
      time.sleep(5)
      print("LTE attach functie... ", end='')
      lte.attach(band=20) # poging tot verbinden, soms nodig, doet iets intern, beetje vaag
      print("OK")
      time.sleep(5)
      time.sleep(5)
      time.sleep(5)
      time.sleep(5)
      time.sleep(5)
      print("wait  5 sec")
      time.sleep(5)
      print("Error report...", end='')
      send_at_cmd_pretty('AT+CEER') # +CEER: lastEmmCause: NO CAUSE RECEIVED, lastEsmCause: NO CAUSE RECEIVED
      time.sleep(5)
      print('Status 2:')
      time.sleep(5)
      print("FSM status 3 ", end='')
      time.sleep(5)
      print("Force register to network...", end='') # ERROR, also the forced network disappears from list
      #send_at_cmd_pretty('AT+COPS=1,2,"20408"') # force select and register network, connect with KPN
      #send_at_cmd_pretty('AT+COPS=1,2,"20416"') # force select and register network, connect with T-Mobile
      print("wacht 30 sec")
      time.sleep(5)
      print("wacht 25 sec")
      time.sleep(5)
      print("wacht 20 sec")
      time.sleep(5)
      print("wacht 15 sec")
      time.sleep(5)
      print("wacht 10 sec")
      time.sleep(5)
      print("wacht  5 sec")
      time.sleep(5)
      print("FSM status 4 ", end='')
      time.sleep(5)
      print("Check signal strength...", end='')
      send_at_cmd_pretty('AT+CSQ') # +CSQ: 24,99 OK
      time.sleep(5)
      print("Connected?...", end='') # +CGATT: 0
      send_at_cmd_pretty('AT+CGATT?')
      time.sleep(5)
      print("Show IP adres:...", end='')
      send_at_cmd_pretty('AT+CGPADDR') # +CGPADDR: 1   +CGPADDR: 2
      time.sleep(5)
      print('Status 3:')
      time.sleep(5)
      print("FSM status 5 ", end='')
      time.sleep(5)
      #lte.deinit()
      print('Finished')
      #send_at_cmd_pretty('AT+COPN') # List operators names
      # LTE/NB: +COPN: "20408","NL KPN"
      #               "20416","T-Mobile"
        robert-hh @ChielvDiepen
        @chielvdiepen There is a problem in the lte.attach() API. @xykon adresses this in a trial firmware build at [LINK NO LONGER AVAILABLE]
        Please download and install that (install from file). It may fix you problem.
        See also this thread around https://forum.pycom.io/topic/3549/important-update-regarding-lte-modem-updates/83 and
          ChielvDiepen
          This is my output of SHOWPHY:
          DL SYNCHRO STATISTICS
              Synchro state                         : DRX_SLEEP
              PPU SIB1 ACQ watchdog                 : 0
              Frequency Hypothesis RF  (Hz)         : 0
              RSRP (dBm)                            : -76.29
              RSRQ  (dB)                            : -7.05
              Channel estimation state (Cell-spec.) : HIGH CINR
              Channel estimation state (UE-spec.)   : LOW CINR
              Channel estimation state (MBSFN)      : LOW CINR
              Channel estimation CINR               : 28.63
              Channel length                        : SHORT
            AGC
              AGC RX gain (dB)                      : 38.58
              RX PSD BO (dBFs)                      : -22.12
              RX PSD (dBm)                          : -80.21
              Noise level RS (dBm)                  : -100.75
              Digital gain (dB)                     : 5.04
              CINR RS (dB)                          : 24.46
            NARROWBANDS
              Last DL NB                            : Central
              Last UL NB                            : 0
            AFC
              Frequency offset RF  (Hz)             : -362
              Frequency offset BB  (Hz)             : 0
            PBCH
              MIB received quantity                 : 91
              MIB timeout quantity                  : 0
          OK
          And FSM:
          SYSTEM FSM
              |            FSM           |        STATE       |
              | RRC TOP FSM              |CAMPED              |
              | RRC SEARCH FSM           |CAMPED_ANY          |
              | RRC ACTIVE FSM           |IDLE                |
              | PMM PLMN FSM             |ANY_CAMPED          |
              | EMM MAIN FSM             |NULL                |
              | EMM AUTH FSM             |NULL                |
              | EMM CONN FSM             |NULL                |
              | EMM TAU FSM              |NULL                |
              | EMM TEST FSM             |NULL                |
              | ESM BEARER FSM           |BEARER_NULL         |
              | SMS MT FSM               |IDLE                |
              | SMS MO FSM               |IDLE                |
              | HP MAIN FSM              |IDLE                |
              | HP USIM FSM              |READY               |
              | HP SMS MO FSM            |IDLE                |
              | HP SMS MT FSM            |IDLE                |
              | HP CAT FSM               |IDLE                |
          OK
            ChielvDiepen
            @robert-hh unfortunately the new software version is not working, but still thank you for the quick reply.
            • O Offline
              optionseven
              @ChielvDiepen We just managed to connect to the KPN LTE-M1 network. Try replacing the following AT-commands:
              OLD:
              NEW:
              send_at_cmd_pretty('AT!="RRC::addScanBand band=20"')
              OLD:
              NEW (notice the typo: ITEM should be LTEM) :
              send_at_cmd_pretty('AT+CGDCONT=1,"IP","ltem.internet.m2m"')
              OR (this is the APN we use):
              send_at_cmd_pretty('AT+CGDCONT=1,"IP","ltem.webtrial.m2m"')
              REMOVE (we didn't need it):
              OLD:
              NEW:
              The xykon firmware is not necessary, this works for us with 1.18.1.r1
              Last but crucial in our case was to upgrade the modem firmware to CAT-M1. Upgrading to NB-IoT overwrites the CAT-M1 firmware and then lte.attach() will not work with the commands above.
              C 1 Reply Last reply Reply Quote 1
                ChielvDiepen @optionseven
                @optionseven When i tried your suggestion code with my code, it gave me an error at ('AT+COPS=1,2,"20408"'). Dont understand why it is working for you. Could you maybe show me your code?
                OK
                wait 10 sec
                wait  5 sec
                Current network...
                +COPS: 1
                OK
                ERROR
                O 1 Reply Last reply Reply Quote 0
                • O Offline
                  optionseven @ChielvDiepen
                  @chielvdiepen are you certain the modem firmware running is CATM1-38638.dup?
                  Here is my code:
                  import ssl
                  def pretty(cmd):
                          print(line)
                  lte = LTE()         # instantiate the LTE object
                  print("Resetting modem:")
                  pretty('AT^RESET')
                  pretty('AT!="fsm"')
                  time.sleep(5)
                  # DL SYNCHRO STATISTICS
                  time.sleep(5)
                  print("Turning off antenna:")
                  pretty('AT+CFUN=0')
                  time.sleep(5)
                  print("Clearing scanning configuration:")
                  time.sleep(5)
                  print("Adding scan frequency for band 20")
                  time.sleep(5)
                  print("Configure PDP Context 1:")
                  time.sleep(5)
                  print("Turning on modem")
                  pretty('AT+CFUN=1')
                  time.sleep(15)
                  print("Registering manually to KPN network:")
                  time.sleep(5)
                  print("Checking which network the modem is registered to")
                  pretty('AT+COPS?')
                  time.sleep(5)
                  # If correctly configured for carrier network, attach() should succeed.
                  if not lte.isattached():
                      print("Attaching to LTE network ", end='')
                      lte.attach()
                      while(True):
                          if lte.isattached():
                              print(" OK")
                              break
                          print('.', end='')
                  # Once attached, connect() should succeed.
                  if not lte.isconnected():
                      print("Connecting on LTE network ", end='')
                      lte.connect()
                      while(True):
                          if lte.isconnected():
                              print(" OK")
                              break
                          print('.', end='')
                  s = socket.socket()
                  s = ssl.wrap_socket(s)
                  s.connect(socket.getaddrinfo('www.google.com', 443)[0][-1])
                  s.send(b"GET / HTTP/1.0\r\n\r\n")
                  print(s.recv(4096))
                  s.close()
                    @optionseven I tried your code, result below. And yes, i updated tot 1.18.1.R1 (latest) and installed the catm1.dup again. So i started with a fresh install.
                    OK
                    Turning on modem
                    OK
                    OK
                    ERROR
                    +CEREG: 2
                    +COPS: 1
                    OK
                    Attaching to LTE network ..............
                    Version of modem:
                    SYSTEM VERSION
                    FIRMWARE VERSION
                    Bootloader0 : 5.1.1.0 [33080]
                    Bootloader1* : 5.1.1.0 [38638]
                    Bootloader2 : 5.1.1.0 [38638]
                    NV Info : 1.1,0,0
                    Software : 5.1.1.0 [38638] by robot-soft at 2018-08-20 09:51:46
                    UE : 5.0.0.0d
                    COMPONENTS
                    ZSP0 : 1.0.99-13604
                    ZSP1 : 1.0.99-12341
                    • M Offline
                      marmarti
                      After upgrading im no longer able to attach. Im not able to find a solution and also not able to find how to return to stock modem firmware.
                      ###CODE
                      lte = LTE(carrier="at&t")
                      lte.attach(band=4)
                      def pretty(cmd):
                      print(line)
                      #Troubleshooting
                      ###get the System FSM
                      AT!="fsm"
                      SYSTEM FSM
                      |            FSM           |        STATE       |
                      | EMM TAU FSM              |NULL                |
                      | SMS MT FSM               |IDLE                |
                      | SMS MO FSM               |IDLE                |
                      | HP MAIN FSM              |IDLE                |
                      | HP USIM FSM              |ABSENT              |
                      | HP CAT FSM               |NULL                |
                      ###Fet the PHY status
                      AT!="showphy"
                      RSRP (dBm)                            : -98.70
                      RSRQ  (dB)                            : -13.89
                      Channel estimation state (Cell-spec.) : LOW CINR
                      Channel estimation CINR               : 1.77
                      AGC
                      AGC RX gain (dB) : 55.16
                      RX PSD BO (dBFs) : -20.15
                      RX PSD (dBm) : -101.62
                      Noise level RS (dBm) : -101.98
                      Digital gain (dB) : 9.87
                      CINR RS (dB) : 3.28
                      NARROWBANDS
                      Last UL NB : 0
                      AFC
                      Frequency offset RF (Hz) : -1323
                      PBCH
                      MIB received quantity : 14
                      International Mobile Subscriber Identity
                      AT+CIMI=?
                      Error
                      ###Signal quality
                      AT+CSQ
                      +CSQ: 15,99
                      PDP Context
                      AT+CGDCONT?
                      +CGDCONT: 1,"IP","web.iusacellgsm.mx",,,,0,0,0,0,0,0
                      ###Network Registration
                      AT+CREG?
                      +CREG: 0,0
                      ###Software Version
                      ATI1
                      UE5.0.0.0d
                      LR5.1.1.0-38638
                      ###ATC Cell Monitoring
                      #Supported values
                      AT+SQNMONI=?
                      #Report from all cells
                      AT+SQNMONI=7
                      +SQNMONI: TELCEL Cc:334 Nc:020 RSRP:-1 RSRQ:-1 TAC:23330 Id:235 EARFCN:2050 PWR:-1 PAGING:128
                      +SQNMONI: TELCEL Cc:334 Nc:020 RSRP:-1 CINR:-1 RSRQ:-1 TAC:23330 Id:235 EARFCN:2050 PWR:-1 PAGING:128
                      ###ICCID (card identification number) on the SIM card.
                      AT+SQNCCID
                      SQNCCID: "",""
                      ###Conformance Test Mode
                      AT+SQNCTM?
                      +SQNCTM: standard
                      • E Offline
                        Elfred
                        I'am giving up.Tried everything to get my FiPy to work on the KPN network, but after several late evenings.....
                        After upgrading the modem tot 39529 he won't run anything anymore.
                        Sounds familiar ?
                        Elfred
                        W 1 Reply Last reply Reply Quote 0
                        • W Offline
                          wghirakawa @Elfred
                          @elfred don't give up. I just got my FiPy working after a month of waiting. Come to find out it was a simple stupid mistake because of incorrect information in the docks. I was using lte.connect(cid=3), as per documentation when on Verizon's, network. This did not work for me. Until I changed to cid=1 and now it works without a hitch. Not sure why that is. I am currently using Verizon M2M Demo sim cards and have been working for the last several days. With some hiccups every now and then, due to power interruptions and server DNS errors.
                          Here is the code I use to connect to verizon now.
                          import ssl
                          debug = True
                          def at(cmd):
                              ("modem command: {}".format(cmd))
                                  print(line)
                          if (debug) : print('creating LTE object - carrier verizon')
                          # lte = LTE()
                          lte = LTE(carrier="verizon")
                          pycom.rgbled(0x7f0000) #red to show LTE established
                          # lte = LTE(carrier="at&t")         # instantiate the LTE object
                          if (debug) : print('resetting modem, may take up to 5 secs...')
                          if (debug) : print('attaching...')
                          lte.attach()        # attach the cellular modem to a base station
                          # lte.attach(band=13)        # attach the cellular modem to a base station
                          while not lte.isattached():
                              if (debug) : print('waiting for isattached...')
                              time.sleep_ms(1000)
                          pycom.rgbled(0x7f7f00) #yellow to show LTE attached
                          if (debug) : print('connecting...')
                          # lte.connect()       # start a data session and obtain an IP address
                          lte.connect(cid=1)    # cid=3 for verizon - start a data session and obtain an IP address
                          while not lte.isconnected():
                              if (debug) : print('waiting for isconnected...')
                              time.sleep_ms(500)
                          pycom.rgbled(0x00007f) #blue to show LTE attached
                          if (debug) : print('create socket')
                          s = socket.socket()
                          if (debug) : print("Connect to: www.ces-web.com")
                          sockaddr = socket.getaddrinfo('www.google.com', 80)[0][-1]
                          #print("Connect to: www.google.com")
                          #s = ssl.wrap_socket(s)
                          #sockaddr = socket.getaddrinfo('www.google.com', 443)[0][-1]
                          if (debug) : print("socket address: {}".format(sockaddr))
                          s.connect(socket.getaddrinfo('www.google.com', 80)[0][-1])
                          pycom.rgbled(0x007f00) #green to show LTE attached
                          if (debug) : print("send GET request")
                          if (debug) : print("receive response")
                          if (debug) : print(s.recv(16))
                          s.close()
                          if (debug) : print("socket closed")
                          pycom.heartbeat(True)
                          If everyone in the world could do their passion, the world would be an unbelievable place!
                          E 1 Reply Last reply Reply Quote 1
                          • E Offline
                            Elfred @wghirakawa
                            @wghirakawa Thanks for the encouragement. After a night sleep I picked it up again. Did a hard reset of the modem, uploaded the latest firmware again (CATM1-39529.dup) and got the equipment running again. But no, no attachment whatsoever. I think I have to dive into the firmware software.
                            • K Offline
                              kjm @Elfred
                              @elfred I had a gpy lte modem die on me. After trying everything I could think of I purchased another gpy and all good again. So weird because wifi, power consumption & all the other functionality still OK. For what it's worth a dead modem fingerprint looks like
                              SYSTEM FSM
                                  |            FSM           |        STATE       |
                                  | RRC TOP FSM              |STOPPED             |
                                  | RRC SEARCH FSM           |NULL                |
                                  | RRC ACTIVE FSM           |NULL                |
                                  | PMM PLMN FSM             |NULL                |
                                  | EMM TAU FSM              |NULL                |
                                  | SMS MT FSM               |IDLE                |
                                  | SMS MO FSM               |IDLE                |
                                  | HP MAIN FSM              |IDLE                |
                                  | HP CAT FSM               |IDLE                |
                              OK
                              and
                                  Synchro state                         : OFF
                                  RSRP (dBm)                            : 0.00
                                  RSRQ  (dB)                            : 0.00
                                  Channel estimation CINR               : 0.00
                                AGC
                                  AGC RX gain (dB)                      : 0.00
                                  RX PSD BO (dBFs)                      : 0.00
                                  RX PSD (dBm)                          : 0.00
                                  Noise level RS (dBm)                  : 0.00
                                  Digital gain (dB)                     : 0.00
                                  CINR RS (dB)                          : 0.00
                                NARROWBANDS
                                  Last DL NB                            : 0
                                  Last UL NB                            : 0
                                AFC
                                  Frequency offset RF  (Hz)             : 0
                                PBCH
                                  MIB received quantity                 : 0
                              Have you checked your sim in another device to verify it's OK?
                              P E 2 Replies Last reply Reply Quote 0
                                Paul Thornton @kjm
                                @kjm Sad to see you lost a board. Thanks for the fingerprint. That's actually quite usefull.
                                • E Offline
                                  Elfred @kjm
                                  @kjm Thanks for the reply. Funny thing is that sometimes I get the fingerprint you've shown in you're post and the other time I get good result in terms of RSRP, RSRQ etc.
                                  I'll check the SIM in an other device. Good thinking.
                                  In the Jasper Wireless portal of KPN I can do a diagnostics test. That one failed. I've asked the question to KPN, but no answer yet.
                                  Thanks again and lets make IoT really work
                                  • E Offline
                                    Elfred
                                    What I see in the FSM of @kjm is HP USIM FSM : Ready.
                                    I See HP USIM FSM: Absent.
                                    No wonder it's not working.
                                    Can't figure out what's wrong.
                                    Going back to KPN
                                    • E Offline
                                      Elfred
                                      Entlich mal. I've got connection. Got finally a new SIM from KPN and it worked immediately . Thanks all for the encouraging words:-)
                                      Now I can start my project.
                                      Keep you posted.
