    Socket errors
    pycomwifioserror
    1 Posts 1 Posters 494 Views 1 Watching
    • W Offline
      Wendfrey
      i'm trying to use sockets to connect two pycom via wifi, in the server socket the server binds, listens and waits for accepts in 127.0.0.1 port 21. The problem is the client socket, I connect the client pycom to the server pycom (it works) and then i get the information via wlan.getaddrinfo(), then i create the socket and i use socket.connect((gateway, port)), gateway = given gateway by getaddrinfo(), port = 21. The error that appears is type OSError and the argument that gives is "-1".
      Also, sometimes the ifconfig() that the clients uses returns 0.0.0.0 ip.
      Any idea of what i am doing wrong?
      client code:
      import network
      from network import WLAN
      import utime
      def exists(name):
          try:
              fich = open(name)
              fich.close()
              return True
          except:
              return False
      def sendInfo(ssidN):
          try:
              if(exists("registro.txt")):
                  print("______START______")
                  wlan = WLAN(mode=WLAN.STA)
                  nets = wlan.scan()
                  for net in nets:
                      if(net.ssid == ssidN):
                          wlan.connect(ssid=net[0], auth=(net[2],"witeklab@2018"),bssid=net[1])
                          pycom.rgbled(0x0F0F0F)
                          break
                      raise Exception("La red", ssidName, "no ha sido encontrada")
                  while not wlan.isconnected():
                      pass
                  print("Conexion establecida")
                  ip, subnet, gateway, dns = wlan.ifconfig()
                  print(wlan.ifconfig())
                  ##PUERTO DE CONEXION
                  port = 80
                  pycom.rgbled(0x0f0f00)
                  fam, type1, proto, oem, asdf = socket.getaddrinfo(gateway, port)[0]
                  sock = socket.socket()
                  print("conectando socket a -> (",gateway, ",", port,")")
                  sock.connect((gateway,port))
                  utime.sleep(1)
                  print("socket conectado")
                  pycom.rgbled(0x000f05)
                  op = "registro.txt"
                  with open(op,"rb") as f:
                      datos = f.read()
                      sock.write(datos)
                      sock.close()
                      wlan.disconnect()
                      print("Datos enviados")
          except Exception as e:
              if isinstance(e,OSError) and sock:
                  sock.close()
              print("Error en initWlan: ", type(e), e)
      sendInfo("Gateway 001")
      pycom.heartbeat(True)
