    WiPy and DHT22 issue
    dht22wipy3.0
    12 Posts 3 Posters 1.5k Views 3 Watching
    • B Offline
      brewnut
      Hi all, Newbie here when it come to micropython so apologies in advance if there is something simple im missing.
      Im attempting to connect a DHT22 to my WiPy on and expansion board 3.0 and have been unsuccessful with getting it to work
      I have attempted to use the WiPy-2.0-DHT22 library from Erikdelange but when running the using_the_dht22.py file i keep getting the following errors
      0 pulses measured
      0 bits
      File "<stdin>", line 59, in <module>
      IndexError: list index out of range
      I presume the list index out of range error is thrown as there are no pulses being measured so an empty list. However i have no idea why im getting no pulses measured and what i'm doing incorrectly unless i have screwed up the wiring or there is something else i need to change in the code.
      Picture of wiring setup.
      Any help would be appreciated.
      Cheers
      BN
        robert-hh @brewnut
        @brewnut Try this code. It works well for me. It should be in micrpython-lib, but I did not find it. Do not ask me why the class is DTH instead of DHT
        from machine import Pin
        class DTHResult:
            'DHT sensor result returned by DHT.read() method'
            ERR_NO_ERROR = 0
            ERR_MISSING_DATA = 1
            ERR_CRC = 2
            error_code = ERR_NO_ERROR
            temperature = -1
            humidity = -1
            def __init__(self, error_code, temperature, humidity):
                self.error_code = error_code
                self.temperature = temperature
                self.humidity = humidity
            def is_valid(self):
                return self.error_code == DTHResult.ERR_NO_ERROR
        class DTH:
            'DHT sensor (dht11, dht21,dht22) reader class for Pycom'
            __dhttype = 0
            def __init__(self, pin, sensor=0):
                self.__pin = Pin(pin, mode=Pin.OPEN_DRAIN)
                self.__dhttype = sensor
                self.__pin(1)
                time.sleep(1.0)
            def read(self):
                # pull down to low
                self.__send_and_sleep(0, 0.019)
                data = pycom.pulses_get(self.__pin,100)
                self.__pin.init(Pin.OPEN_DRAIN)
                self.__pin(1)
                bits = []
                for a,b in data:
                        if a ==1 and 18 <= b <= 28:
                                bits.append(0)
                        if a ==1 and 65 <= b <= 75:
                                bits.append(1)
                if len(bits) != 40:
                    return DTHResult(DTHResult.ERR_MISSING_DATA, 0, 0)
                # we have the bits, calculate bytes
                the_bytes = self.__bits_to_bytes(bits)
                # calculate checksum and check
                checksum = self.__calculate_checksum(the_bytes)
                if the_bytes[4] != checksum:
                    return DTHResult(DTHResult.ERR_CRC, 0, 0)
                # ok, we have valid data, return it
                [int_rh, dec_rh, int_t, dec_t, csum] = the_bytes
                if self.__dhttype==0:           #dht11
                    rh = int_rh                 #dht11 20% ~ 90%
                    t = int_t   #dht11 0..50°C
                else:                   #dht21,dht22
                    rh = ((int_rh * 256) + dec_rh)/10
                    t = (((int_t & 0x7F) * 256) + dec_t)/10
                    if (int_t & 0x80) != 0:
                        t = -t
                return DTHResult(DTHResult.ERR_NO_ERROR, t, rh)
            def __send_and_sleep(self, output, mysleep):
                self.__pin(output)
                time.sleep(mysleep)
            def __bits_to_bytes(self, bits):
                the_bytes = []
                byte = 0
                for i in range(0, len(bits)):
                    byte <<= 1
                    if (bits[i]):
                        byte |= 1
                    if ((i % 8) == 7):
                        the_bytes.append(byte)
                        byte = 0
                return the_bytes
            def __calculate_checksum(self, the_bytes):
                return the_bytes[0] + the_bytes[1] + the_bytes[2] + the_bytes[3] & 255
        th = DTH(Pin('P8', mode=Pin.OPEN_DRAIN),1)
        def run():
            pycom.rgbled(0x000008) # blue
            time.sleep(0.5)
            result = th.read()
            if result.is_valid():
                pycom.rgbled(0x001000) # green
                print("Temperature: %.1f C" % result.temperature)
                print("Humidity: %.1f %%" % result.humidity)
        run()
        • B Offline
          brewnut @robert-hh
          @robert-hh thanks for this. I have also tried running this code from Jurassic Pork and i get nothing at all when i run it.
          I have changed the pin to G22 so it matches my wiring for both sets of code.
          I will give the code from Daniel a go as well.
          This is the code from Jurassic Pork
          this is the DTH.py file
          from machine import enable_irq, disable_irq,  Pin
          class DTHResult:
              ERR_NO_ERROR = 0
              ERR_CRC = 2
              temperature = -1
              humidity = -1
              def is_valid(self):
          class DTH:
              __pin = Pin(Pin.exp_board.G22, mode=Pin.OPEN_DRAIN)
              print(__pin)
              __dhttype = 1
              def __init__(self, pin, sensor=1):
                  self.__pin(1)
                  time.sleep(1.0)
              def read(self):
                  # pull down to low
                  self.__pin(1)
                  #print(data)
                  bits = []
                  for a,b in data:
                  		bits.append(0)
                  		bits.append(1)
                          #print("longueur bits : %d " % len(bits))
                  if len(bits) != 40:
                  #print(bits)
                  else:			#dht21,dht22
                      if (int_t & 0x80) > 0:
                          t *= -1
                  self.__pin(output)
                  time.sleep(mysleep)
                  the_bytes = []
                  byte = 0
                      byte = byte << 1
                      if (bits[i]):
                          byte = byte | 1
                          byte = byte | 0
                      if ((i + 1) % 8 == 0):
                          byte = 0
                  #print(the_bytes)
                  return the_bytes
          this is the DHT22_example.py code
          from dth import DTH
          th = DTH(Pin.exp_board.G22,1)
          print(th)
          time.sleep(2)
          result = th.read()
          print(result)
              print('Temperature: {:3.2f}'.format(result.temperature/1.0))
              print('Humidity: {:3.2f}'.format(result.humidity/1.0))
          Running the DHT22_example code seems to stall somewhere after the LED changes to blue as it does not change to green. I presume this is because the result is not valid.
          • B Offline
            brewnut
            Ok I have since added a one wire temp sensor to the board and got that working so have now come back to the dht22.
            I am still getting the zero pulses received error so will look to see how I go debugging. Any tips would be appreciated.
              robert-hh @brewnut
              @brewnut When you take the voltage at the data pin, it should be about 3.3V. Do you have to visualize the data signal, like with a logic analyzer or Oscilloscope?
              • B Offline
                brewnut @robert-hh
                @robert-hh no sorry I don’t have an Oscilloscope. Anything else I can do with the code to troubleshoot eg print out results at certain steps to see where it is failing?
                  robert-hh @brewnut
                    robert-hh @brewnut
                    @brewnut did you try to take my code example below and replace 'P8' by 'P12', which is your wiring?
                    • B Offline
                      brewnut @robert-hh
                      @robert-hh Hi Robert i have just tried your code replacing 'P8' with 'P11' (thats actually what the yellow jumper wire is plugged into).
                      Noting happens when running this.
                      I also tried replacing the __dhttype = 0 with = 1 as reading over the DTH code notes it mentions the DHT 11 sensor is type 0 and DHT 22 sensor is type 1.
                      Changing these settings also results in noting happening when running.
                      • FridaF Offline
                        Frida
                        If you want to use 'P11' (G22), try removing the 'RTS' jumper as it is connected to 'program port'.
                        See: https://docs.pycom.io/.gitbook/assets/wipy3-pinout.png
                        • B Offline
                          brewnut @Frida
                          @frida thanks for this suggestion, I will give a go and report back. Any particular reason the RTS jumper is linked to P11. Should I try a different pin instead and leave the RTS jumper in place?
                            robert-hh @brewnut
                            @brewnut The RTS pin is not used by the firmware, but driven by the UAB/UART bridge. But you can also use another pin, like P6.
