    Firmware release 1.0.1.b1
    28 Posts 9 Posters 8.7k Views 9 Watching
      DongYin
      @daniel
      I set my Lopy to WLAN.STA mode and connect it with the router, then i ping it's IP address on my computer successfully.
      But if there is a way i can ping the IP address of my computer on the Lopy.
      If and how i can save any data to the flash?
        livius @DongYin
        @DongYin said in Firmware release 1.0.1.b1:
        you can write files to the `\flash' folder without any problem
        • R Offline
          Ralph
          @livius, before Daniel replies, let me add that (if you didn't know this already,) you can still update your board manually by placing the bin file in the /sys directory on the board itself using FTP, then rebooting the board. Your idea of making it an option in the updater would probably be better, but until that happens, you can do it this way.
          Edit: This works even nicer:
          make BOARD=LOPY ESPPORT=/dev/ttyUSB0 flash
            livius @Ralph
            @Ralph said in Firmware release 1.0.1.b1:
            what this command flash do?
            write e.g. appimg.bin or also partition.bin, bootloader.bin some other things like erase mem...
            EDIT
            this does not work for me - but i tested this tommorow only once at night
            then maybe i do something wrong
            when i do this and restart the board it do not run
            i then reflash it with the updater tool once again
            and flash board with command line to put my custom source code make
            updater.py -f ......
            but i must change script of updater.py and remove erase_sytem_mem steap
            from some reason this steap time out
            a little hint here 'erase_sytem_mem' have one letter typing error should be 'erase_system_mem' ;-)
            • R Offline
              Ralph
              @livius it writes all three .bin files, but it doesn't erase anything else on the file system.
                livius @Ralph
                @Ralph
                thank you for the explanation
                one question here - why then updater tool do erase mem?
                EDIT:
                and for windows it is like this?
                make BOARD=WIPY ESPPORT=COM6 flash
                • R Offline
                  Ralph
                  @livius As I understand from my colleagues, the updater tool does the same as the flash command does: it only erases what it needs to, to write the firmware, partition and bootloader.
                  And yes that looks about right to me for windows. ESPPORT just needs to be the full comport.
                  L 1 Reply Last reply Reply Quote 1
                    livius @Ralph
                    @Ralph
                    ok - maybe this steap is unnesceserry at all it is used only if args.tar = None
                    in update.py is
                        def erase_sytem_mem(self):
                            # Erase first 3.5Mb (this way fs and MAC address will be untouched)
                            self.erase(0, 0x3100000)
                    i will use flash switch from make
                    thank you again
                      DongYin @livius
                      @livius said in Firmware release 1.0.1.b1:
                      Thank you! i used uos.mkdir("setting.ini") to write a file to '\flash', then how to write&read it by programs?
                        livius @DongYin
                        @DongYin
                        look at:
                        https://docs.python.org/3/tutorial/inputoutput.html
                        there are paragraphs about files
                        also look here
                        https://docs.pycom.io/pycom_esp32/library/uos.html
                        os.mkdir create directory
                        • 1
                        • 2
                        • 2 / 2
