    Atom foibles.
    atomgpyrepl
    4 Posts 2 Posters 474 Views 2 Watching
    • K Offline
      kjm
      Experiencing a couple of Atom issues I can't seem to fix. Just wondering if anyone has encountered the same problems & has found solutions?
      1. If I'm editing code & click Run Atom sometimes runs the onscreen program, sometimes the saved version in the project folder on the PC & sometimes the saved version in flash on the gpy. This means I have to click save & upload after every edit to be sure all versions match which is a bit of a pain.
      2. If I lose the USB connection to the gpy then reconnect the Run button has mysteriously vanished so I have to close then reopen Atom to get it back again.
        JohnPiantanida @kjm
        @kjm I have noticed the same things.
        #1 has forced me to remember to save first... which I think is good for me (knowing my work habits). But I don't need to upload, it will run the saved version (for me at least) without doing the upload.
        #2 Is a real pain. Sometimes doing a forced disconnect, then connect again clears it up, but not always. It becomes even more of a problem when I have multiple instances of Atom open attached to different boards. Once it happens it seems to cause other instances to behave the same way. Maybe it is a problem that effects a shared resource? So rather that waste time trying, I close them all down and reopen each which is a REAL PAIN since only one is "remembered" and the rest need to be browsed to so they can be reopened.
        • K Offline
          kjm
          Shared misery then!
            JohnPiantanida @kjm
            @kjm But maybe since we are mentioning it... someone who already has a fix can pass it along. Or someone who didn't realize it was a problem can make the next version a little bit better.
            Hopefully shared misery will have a shared cure. ;)
