    nb-iot on t-mobile in NL
    fipynb-iotconnect issuesconnectionconnect
    12 Posts 2 Posters 1.3k Views 2 Watching
    • E Offline
      Eric Waai
      Re: nb-iot on t-mobile NL
      as for how far we are now this should be possible.
      i have send my fipy's back and i should have band 8 support now.
      is there anyone with an example on how to connect here.
      So far i can't do a succesfull attach to the network but maybe there are other settings needed than stated in the nb-iot connect example
        robert-hh @Eric Waai
        @eric-waai Did you update both the sequans firmware and the ESP32 firmware to the most recent version ?
        And also, the first attach may take very long time, like 20 minutes.
        • E Offline
          Eric Waai
          yes modem software is NB1-40343
          esp32 firmware is the last stable release 1.18.1.r7
          for now i waited over 1 hour without attach
            @eric-waai i 1hour is too long.
            what is the result of lte.send_at_command('At+CSQ') while waitung for is_attached()
            • E Offline
              Eric Waai
              @robert-hh
              AT+CSQ is usually around 23-25,99
              CREG gives (1,0)
              and CEREG also (1,0)
              which would indicate it is somewhat connected
              but CGATT gives 0
                @eric-waai CEREG1,0 means:
                enable network registration unsolicited result code (1) and
                not registered, MT is not currently searching an operator to register to (0)
                You should see something like CEREG 2,0 or CEREG 2,2 while searching.
                AT+CSQ result is good. It means, the device detects a strong signal.
                I'm testing with v1.20.0.rc3
                • E Offline
                  Eric Waai
                  according http://m2msupport.net/m2msupport/atcreg-network-registration/
                  CREG 1,0
                  means registered, home network
                  on GSM
                  i assumed that for CEREG it meant somewhat the same
                  will try again tomorrow
                    @eric-waai As far as I understand it, the coding for CREG and CEREG is the same. The 0 means: not registered, not searching.
                    At my set-up, while waiting for attach, the result of AT+CEREG? is 2,2 most of the time and rarely 2,0
                    • E Offline
                      Eric Waai
                      @robert-hh
                      still not getting anywhere
                      this is the result of showpy
                      DL SYNCHRO STATISTICS
                      Synchro state : DRX_SLEEP
                      PPU SIB1 ACQ watchdog : 0
                      Frequency Hypothesis RF (Hz) : 0
                      RSRP (dBm) : -82.24
                      RSRQ (dB) : -12.62
                      Channel estimation state (Cell-spec.) : LOW CINR
                      Channel estimation state (UE-spec.) : LOW CINR
                      Channel estimation state (MBSFN) : LOW CINR
                      Channel estimation CINR : 5.23
                      Channel length : SHORT
                      AGC
                      AGC RX gain (dB) : 42.57
                      RX PSD BO (dBFs) : -18.79
                      RX PSD (dBm) : -83.06
                      Noise level RS (dBm) : -87.31
                      Digital gain (dB) : 3.90
                      CINR RS (dB) : 5.07
                      NARROWBANDS
                      Last DL NB : Central
                      Last UL NB : 0
                      AFC
                      Frequency offset RF (Hz) : -447
                      Frequency offset BB (Hz) : 0
                      PBCH
                      MIB received quantity : 0
                      MIB timeout quantity : 0
                      if i send AT+COPS=1,2,"20416" (tmobile specific)
                      i get
                      +CEREG: 2
                      +CREG: 2
                      OK
                      +CGATT: 0
                      OK
                      +CEREG: 1,2
                      OK
                      +CFUN: 1
                      OK
                      OK
                      OK
                      +CGATT: 0
                      OK
                      +CEREG: 1,2
                      OK
                      +CFUN: 1
                      OK
                      OK
                      as return
                      if i later again send AT+C(E)REG
                      i get +CREG: 1,0
                      lte.isattached() is still false
                      but the statistics change
                      Synchro state : CELL_ACQUIRED
                      RSRP (dBm) : -82.88
                      RSRQ (dB) : -11.70
                      Channel estimation state (Cell-spec.) : HIGH CINR
                      Channel estimation CINR : 6.45
                      AGC
                      AGC RX gain (dB) : 42.49
                      RX PSD BO (dBFs) : -20.98
                      RX PSD (dBm) : -84.72
                      Noise level RS (dBm) : -89.38
                      Digital gain (dB) : 5.66
                      CINR RS (dB) : 6.50
                      NARROWBANDS
                      Last UL NB : 0
                      AFC
                      Frequency offset RF (Hz) : -452
                      PBCH
                        @eric-waai b.t.w.: which apn have you specified?
                        I found a link where some of that is discussed: https://forum.iot.t-mobile.nl/topic/25/nieuwe-settings-voor-nb-iot-hardware-en-api/11
                        • E Offline
                          Eric Waai
                          @robert-hh
                          hmm i can try that settings
                          i used this settings
                          Frequency Range: Guard Band
                          Radio band: band 8, 900 Mhz
                          APN: cdp.iot.t-mobile.nl
                          PLMN ID: 20416
                          NCDP address for Neul Messaging (CoAP): 172.27.131.100 Port 5683
                          CDP address for UDP messaging: 172.27.131.100 Port 15683
                          Hostname for using the API: https://iot.netwerk.t-mobile.nl
                          Supported TLS certifications: TLS v1.1 and TLS v 1.2
                          as described here
                          https://docs.iot.t-mobile.nl/docs/general-settings
                            @eric-waai These settings should be fine then.
