    Does too much code and libraries uploaded lead to main.py not launching ?
    uploadcodepycom
    4 Posts 4 Posters 612 Views 4 Watching
    • B Offline
      brossingo
      robert-hhR C 2 Replies Last reply Reply Quote 0
        Paul Thornton
        Hey there,
        Im pretty sure the board being full isnt the issue here. Just to clarify you mention it doesnt work when connected to a pc, does this mean it works when powered via battery?
        Paul
          robert-hh @brossingo
          @brossingo That depends on which board you use and how much memory each module needs. But looking at your screen shot, memory shortage is not likely the case, as @Paul-Thornton said.
          As a rule of thumb: unless your code allocates huge data structures, you can expect 10 lines of code/kByte to work fine. On a WiPy2 or LoPy1 this is about 500 lines of code, on all other boards it is about 25000. About twice that number if you pre-compile the code.
            crumble @brossingo
            Try to cross compile the lib folder.
            It may be a memory fragmentation problem, so you cannot allocate the needed buffer size.
