    [solved] PyBytes Flash - text modifying a file disappears after a second
    pybytesbrowserflashedit
    3 Posts 2 Posters 382 Views 2 Watching
      dnear1
      I used to be able to manually develop code from within the Pybytes Flash tab. provided the file existed and I didn't sufficiently brick the device remotely.
      Today, I noticed that when I try to modify text, after about a second, the text I just entered disappears. If I want to put something in, I had to quickly paste and 'push changes' in quick succession.
      I thought maybe this was a quirk with the new device I just provisioned... so I went back to two prior devices and did the same thing... If I picked an existing file and changed something, it disappeared. Did something change with Pybytes website functionality?
      I'm using Firefox on Ubuntu 18.04
      J 2 Replies Last reply Reply Quote 0
        jirkakrepl @dnear1
        Hi, @dnear1 thank you for reaching us. I have fix ready. and we're going to deploy the fix today.
        Sorry for the inconveniences. I will reply here while, we deployed it.
        software developer @ Pycom
          jirkakrepl @dnear1
          @dnear1 We deployed the fix now
