    Exceptions in micro python
    micropythonexceptions
    12 Posts 4 Posters 2.0k Views 5 Watching
    • K Offline
      kjm
      try:
          1/0
      except Exception as e:
          sys.print_exception(e)
      produces
      division by zero
        File "<stdin>", line 4, in <module>
      ZeroDivisionError: division by zero
      But I'd like to be able to store the error and the line number that produced it in a file instead of printing it. Storing the error is easy enough
      with open('ErrorFile', 'wb') as f: f.write(str(e))
      but I can't figure out a way to access & store the line number. Anyone out there in the pycom firmament mastered this trick?
      E R 2 Replies Last reply Reply Quote 0
      • E Offline
        Eric73 @kjm
        @kjm in documentation function prototype is
        sys.print_exception(exc, file=sys.stdout)
        Have you try to open a file and use it with sys.print_exception to see what happened inside the file?
        (Sorry i have no module to test)
          robert-hh @Eric73
          @eric73 just tried thst on windows MP. If you open a file beforehand, you can use that file handle as second argument to sys.print_exception.
          • K Offline
            kjm
            not on the gpy you can't!
              robert-hh @kjm
              @kjm I'll have to check that tonight. I have no device here at the moment.
              • K Offline
                kjm
                Anybody out there manage to store traceback line numbers to a file on the gpy?
                  robert-hh @kjm
                  @kjm You could do as follows:
                  try:
                      1/0
                      import sys
                      with open("error.log", "a") as f:
                          sys.print_exception(e, f)
                  This works for me,
                  Pycom MicroPython 1.20.0.rc6 [8d824a0-dirty] on 2019-01-28; FiPy with ESP32
                  • K Offline
                    kjm
                    Ah, perfect! Tanks muchly.
                    • K Offline
                      kjm
                      Hey Robert I need to filter out the double inverted commas before I store in the error.log file I tried
                      err=sys.print_exception(e)
                      err=err.replace('"',"")
                      but I got AttributeError: 'NoneType' object has no attribute 'replace'
                        robert-hh @kjm
                        @kjm follow these steps. I just executed at the prompt:
                        >>> from uio import StringIO
                        >>> import sys
                        >>> s = StringIO()
                        >>> try:
                        ...     1/0
                        ... except Exception as e:
                        ...     sys.print_exception(e, s)
                        >>> x=s.getvalue()
                        >>> x
                        'Traceback (most recent call last):\n  File "<stdin>", line 2, in <module>\nZeroDivisionError: divis
                        ion by zero\n'
                        • K Offline
                          kjm
                          Thnx again Robert, for anyone else with a similar requirement I ended up with....
                            import sys; from uio import StringIO
                            s=StringIO(); sys.print_exception(e, s)
                            s=s.getvalue(); s=s.split('\n')
                            line=s[1].split(','); line=line[1]; error=s[2]; err=error+line; print(err)
                            with open ('error.log', 'a') as f: f.write(err)
                          • R Offline
                            ronald gevern Banned @kjm
