    Modem's radio showphy, all zeros, is bad?
    modemzerosissue
    7 Posts 3 Posters 691 Views 4 Watching
      Jordan Reyes
      One of my pycom units stopped attaching.
      It seems like the modem module is responsive but maybe radio is dead, or stuck.
      I would not expect all zeros
      My question is it stuck or fried?
      Ran this:
      def send_at_cmd_pretty(cmd):
        needResume = False
        if lte.isconnected():
          lte.pppsuspend()
          needResume = True
        response = lte.send_at_cmd(cmd).split('\r\n')
        if needResume:
          lte.pppresume()
        for line in response:
          print(line)
      lte = LTE()
      lte.init()
      send_at_cmd_pretty('AT!="showphy"')
      Got This:
      DL SYNCHRO STATISTICS
          Synchro state                         : IDLE
          PPU SIB1 ACQ watchdog                 : 0
          Frequency Hypothesis RF  (Hz)         : 0
          RSRP (dBm)                            : 0.00
          RSRQ  (dB)                            : 0.00
          Channel estimation state (Cell-spec.) : LOW CINR
          Channel estimation state (UE-spec.)   : LOW CINR
          Channel estimation state (MBSFN)      : LOW CINR
          Channel estimation CINR               : 0.00
          Channel length                        : SHORT
        AGC
          AGC RX gain (dB)                      : 0.00
          RX PSD BO (dBFs)                      : 0.00
          RX PSD (dBm)                          : 0.00
          Noise level RS (dBm)                  : 0.00
          Digital gain (dB)                     : 0.00
          CINR RS (dB)                          : 0.00
        NARROWBANDS
          Last DL NB                            : 0
          Last UL NB                            : 0
        AFC
          Frequency offset RF  (Hz)             : 0
          Frequency offset BB  (Hz)             : 0
        PBCH
          MIB received quantity                 : 0
          MIB timeout quantity                  : 0```
      X 1 Reply Last reply Reply Quote 2
      • X Offline
        Xykon administrators @Jordan Reyes
        @jordan-reyes That output is normal when the radio is disabled (it's not enabled automatically during init. Also lte.init() is run when you instantiate the LTE class (lte = LTE()) so running it again has no effect.
        You first need to run lte.attach() in order to activate the radio. Then please run lte.isattached() several times before trying the showphy command again.
        Can you please also run send_at_cmd_pretty('AT+SQNMONI=9') after trying to attach?
        Christian Ehlers
          jason_gladen
          @jordan-reyes said in Modem's radio showphy, all zeros, is bad?:
          AT!="showphy"
          >> print(lte.send_at_cmd('AT+SQNMONI=9'))
          ERROR
          >>> lte.isattached()
          False
          >>> lte.isattached()
          False
          >>> lte.isattached()
          False
          >>> lte.isattached()
          False
          >>> lte.isattached()
          False
          >>> print(lte.send_at_cmd('AT!="showphy"'))
              Synchro state                         : OFF
              RSRP (dBm)                            : 0.00
              RSRQ  (dB)                            : 0.00
            AGC
              RX PSD (dBm)                          : 0.00
              CINR RS (dB)                          : 0.00
            NARROWBANDS
              Last DL NB                            : 0
              Last UL NB                            : 0
            AFC
            PBCH
          OK
          >>> lte.init();
          >>> lte.init()
          >>> lte.isattached()
          False
          >>> lte.isattached()
          False
          >>> lte.isattached()
          False
          >>> lte.isattached()
          False
              Synchro state                         : OFF
              RSRP (dBm)                            : 0.00
              RSRQ  (dB)                            : 0.00
            AGC
              RX PSD (dBm)                          : 0.00
              CINR RS (dB)                          : 0.00
            NARROWBANDS
              Last DL NB                            : 0
              Last UL NB                            : 0
            AFC
            PBCH
          OK
          ERROR
          ERROR
          X 1 Reply Last reply Reply Quote 1
          • X Offline
            Xykon administrators @jason_gladen
            @jason_gladen You need to run lte.attach() first to enable the radio. The modem might restart when using this command so it's necessary to check with lte.isattached() if the radio needs to be re-enabled after the reset.
            Christian Ehlers
              jason_gladen @Xykon
              @xykon
              I had tried it with and without an attach after a 10 second power off/on.
              That run did include an lte.attach() just prior. I thought I pasted it.. I tried it again just to be sure.
              If the radio is not enabled. What could cause that?
              Is there anything else I should try?
              • X Offline
                @jason_gladen Is the SIM card inserted the correct way? https://docs.pycom.io/gettingstarted/connection/fipy.html#sim-card-
                To check if the radio is enabled please run print(lte.send_at_cmd('AT+CFUN?'))
                Christian Ehlers
                  jason_gladen @Xykon
                  @xykon said in Modem's radio showphy, all zeros, is bad?:
                  the print(lte.send_at_cmd('AT+CFUN?')) reported 4 before the attach and 1 after
                  lte.iccid() reports:
                  8944501810180163302"
                  i noticed a funny double-quote at the end but it did that before the modem firmware update and worked fine
