    Display SSD1306 with lopy4 doesn't work
    ssd1306oledspi
    5 Posts 3 Posters 648 Views 3 Watching
      geda
      I am trying to display something on an oled 1306 with lopy4, but it doesn't work.
      I have try SPI with this librairie https://github.com/dmitryelj/LoPyI2CLCD.
      I have bought this piece on aliexpress: https://fr.aliexpress.com/item/1-3-inch-Blue-OLED-Module-SSD1106-Drive-IC-Compatible-with-SSD1306-IC-128-64-IIC/32655103082.html?spm=a2g0s.9042311.0.0.27426c37EFOTpR
      Any idea of what could be wrong ?
      Code
      f name == "main":
      import sys, machine, os
      print("Started")
      displayType = kDisplaySPI128x64
      initialize(displayType)
      if isConnected():
          set_contrast(255) # 1-255
          displayOn()
          clearBuffer()
          addString(0, 0,  sys.platform + " " + sys.version)
          addString(0, 1,  "---")
          #addString(0, 2,  "CPU: {} MHz".format(machine.freq()[0]/1000000))
          #addString(0, 4,  "Version: {}".format(os.uname().release))
          addString(0, 5,  "LoPy font test")
          addString(0, 6,  "AaBbCcDdEeFfGgHhIi")
          addString(0, 7,  "0123456789012345")
          drawBuffer()
          print("Error: LCD not found")
      print("Done")
        Paul Thornton
        Do you see any errors in the console?
        Does yours "test" string print out ok?
        or Is it simply that it wont display anything on the screen
          robert-hh @geda
          @geda The device can be operate deither in SPI or I2C mode (soldered jumper at the back side). Did you check that it is SPI?
          And it tells that it's a SSD1106 driver chip. I cannot find any data sheet for that. Could be an SH1106. For that one, I have a driver here, initially made for ESP8266. https://github.com/robert-hh/SH1106
            geda @robert-hh
            @robert-hh , Yes I have check that the jumper is not soldered (spi mode). I did not work with your librarie as well, so give up and will order a new display.
            Thanks for your help
              geda
              @paul-thornton no error display on the console and the display does not show anything. I give up with this module.
