OSerror with rgbled
setup:
Pycom Lopy1
f/w: 1.18.2
atom+pymakrI have a main.py of:
main.py -- put your code here!
time.sleep(2)
print('main MAC1')
print('LED test')
print (0xffffff)
pycom.rgbled(0x0)Using atom I can run this file from the Run command, but it fails when synced with an OSError. It is also ok entering the code at the command line. The error is occurring on the rgbled code. If I # comment the line the following code does not error.
This is the complete trace from run or press of the lopy reset button:
ets Jun 8 2016 00:22:57
ets Jun 8 2016 00:22:57rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff8028,len:8
load:0x3fff8030,len:1688
load:0x4009fa00,len:0
load:0x4009fa00,len:14592
entry 0x400a059c
main MAC1
LED test
16777215
File "main.py", line 12, in <module>
OSError: the requested operation is not possible
Pycom MicroPython 1.18.2 [v1.8.6-849-07a52e4] on 2019-02-08; LoPy with ESP32
Type "help()" for more information.Note, this sample is from a larger code sample and I've taken back to the minimum lines that create the error.
I've reflashed the lopy successfully to latest code.Any ideas?
time.sleep(2)
import pycompycom.heartbeat(False)
print('main MAC1')
print('LED test')
print (0xffffff)
pycom.rgbled(0x0)Try this code. This should run perfectly fine.
@johnmcdnz you need to explicitly turn the heartbeat off before you can set a colour on the LED.
