Trouble uploading to FiPy
Hello, I'm having a problem uploading to my FiPy,
This is the last message I received after trying a hard reset:
rst:0x7 (TG0WDT_SYS_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff9028,len:8
���x��xx�xxf�x��f������x������x���x��f������������x~f�������怘����x���x��f������x怘�f����f�����f���Traceback (most recent call last):
File "main.py", line 4, in <module>
ImportError: no module named 'LIS2HH12'But most of the time I get this message:
Uploading project (main folder)...
Safe booting device... (see settings for more info)
Safe boot failed, uploading anyway.
Upload failed.: timeout Please reboot your device manually.Would be very grateful for any help you could give. The board is brand new so the firmware should be up to date
I had the same problem for FiPy but not sure if it is the same reason. But for my case after I updated the firmware for the FiPy it works normally now. Try it.
Download the firmware update tool from the link below
https://docs.pycom.io/gettingstarted/installation/firmwaretool.html#firstPlease be aware that the firmware for the FiPy is different the firmware for the Pysense.
