    no data in line chart
    pybytes
    5 Posts 2 Posters 479 Views 2 Watching
    • E Offline
      Eric Waai
      I have a problem with pybytes where there is no data displayed in a line chart.
      i have a couple of line graphs which don't get updated while the table is.
      I made a new variable which is displayed as it should.
      edit:
      i just deleted the graph and made a new one and it shows the data alright. somewhere there is something going wrong
      edit2:
      i started goofing around with some line chart settings and i think i found where the problem occurs.
      the variable was about 25 times today and the last time before was 7 days ago. if i increase the pull size so that the data points from 7 days ago should be displayed it shows: no recent data.
        jirkakrepl
        Hi Eric,
        I tried to replicate the problem here, but couldn't at this moment.
        If you found a workaround at this moment, it's good.
        At this moment I would also recommend creating a signal with a signal_number which you haven't used previously.
        I saw that there's another issue (which I haven't tested much yet). if I increase a pull size to 100, the frontend will crash with a white screen. After browser reload graphs aren't showing any useful data.
        software developer @ Pycom
        • E Offline
          Eric Waai @jirkakrepl
          @jirkakrepl
          my signals do have a signal number
          for now it works if there is no big difference(7 days) between the date of the data points.
            jirkakrepl @Eric Waai
            @eric-waai we will take a look at this bug.
            It would help us, if you can spot it again, to tell us how to reproduce it more easily.
            You said that if there's one-week interval then it will fail. Maybe it can be broken also in another way...
            • E Offline
              @jirkakrepl
              today there is no data displayed
              the last samples are from 3 days ago.
              if i have a pull size of 20 it says no recent data.
              the best thing for me with those line graphs is to select the time scale and it plots al the data points in between.
